Switchbot hub connexion
I try to connect home assistant with swichbot hub.
Home assistant is connected by an ethernet cable.
Home assistant is supervised on docker.
When I try to add the integration I receive a message that no non configured device was found.
I successfuly connect switchbox to google home and i would like to connect to home assistant.
I need a bit of help… many thanks in advance
