Switchbot intergration error
I have a few switchbot devices and one of them is the little actuator that turns on a physical switch. But its 50/50 on if it works using the native switchbot intergration I get this error alot:
 Error executing script. Error for call_service at pos 1: Client error occurred when calling resource "https://api.switch-bot.com/v1.0/devices/xxxxxxxxxxx/commands"
But then if I hit the button again it works, I thougnt it might have been my API call rate, as I had the old method of setting it up in the config file still running, I removed that and waited a few days but it still happens.
I have just set up my BT proxy network so I can control this locally anyway, but I am wondering if anyone else is seeing this issue?
Isn’t bluetooth control great? 50-50 is often about right in my experience, and with no feedback, well, almost worthless.
the 50/50 is using the switchbot cloud, I am finding that BT so far works 95 out of 100 times so far.
