Switchbot Meter support without HA
I have incorrectly placed esp thermostats in my house, so I wanted to add external sensors to them. I have a Switchbot Meter, so I wanted to add it to one of the thermostats, but did not find any useful data on how to do it other than using a bluetooth proxy and using home assistant. This would work, but it would create an unnecessary step and if HA goes down I would loose the sensor values.
Experimented with the readings and the logic seems pretty simple. Now it works without HA, but I thought I will share it, maybe somebody finds it useful. Battery reading are not exact, but it could be a good indicator (228 seems to be the max and capped around 2.9V, 140 was reported with a battery that was used for 2 years and I measured 2.116V on it, had no issue, but I considered it low enough to be counted as 0.
Here is a template:
    name: "External sensor Temperature"
    unit_of_measurement: "°C"
    device_class: "temperature"
    state_class: "measurement"
    accuracy_decimals: 1
    name: "External sensor Humidity"
    unit_of_measurement: "%"
    device_class: "humidity"
    accuracy_decimals: 0
    name: "External sensor Battery"
    device_class: "battery"
    filters:
      - calibrate_linear:
          - 140 -> 0
          - 228 -> 100
esp32_ble_tracker:
  on_ble_advertise:
    - mac_address: C4:59:63:49:FF:64
      then:
        - lambda: |-
            for (auto &data : x.get_service_datas()) {
                if (data.uuid.get_uuid().uuid.uuid16 == 0x0D00 && data.data.size() >= 6) {
                    // Temperature: Byte 4 (integer offset 128) + Byte 3 (decimal /10)
                    float t_integer = (int)data.data[4] - 128;
                    float t_decimal = (float)data.data[3] / 10.0;
                    float final_temp = t_integer + t_decimal;
                    // Humidity: Byte 5
                    float final_hum = data.data[5];
                    // Battery: Byte 2
                    float raw_batt = data.data[2];
                    id(room_temp).publish_state(final_temp);
                    id(room_humidity).publish_state(final_hum);
                    id(room_battery).publish_state(raw_batt);
