SwitchBot Relay 2PM cover.stop
I installed a SwitchBot Relay 2PM to control my electric shutters. It was connected to Home Assistant via Matter. The device is working so far and can be controlled.
However, the stop button in Home Assistant is not working. When the command cover.stop_cover is given, the Switch Bot moves the shutter to the last known position.
The SwitchBot app has a pause button. This stops the roller shutter. Does anyone have a similar problem and a solution for it?
