Switches disappeared from Tuya
Greetings,
I can’t understand why two switches (one wall panel with two switches) that have always worked in HA suddenly turn out to be unavailable. I checked through the Smart Life App and both work perfectly, but within LocalTuya they are grayed out and not accessible. I also turned the power off and back on, but nothing changed. I have tried restarting HA and reloading LocalTuya integration without success. What else could I do? Thanks in advance
Do they still have the same IP addresses?
Are they in tuya integration? If they are in tuya integration and they are unavailable in local tuya after all that, then you will have to delete it from local tuya and add again.
Don’t buy tuya wifi switches.
@Neil_Brownlee
Wall panel has only one IP
@ddaniel
Actualy in LocalTuya I see the wall panel but I don’t see the two switches. Tonight I will also try to delete the wall panel from LocalTuya, hoping to remember how to reinsert it to integration.
Thank you.
I removed most of my tuya wifi switches. You need key from tuya iot to integrate tuya wifi device to local tuya. Or just use it in tuya integration. Local tuya is not local and I don’t really know why this exist.
