how can I define a variable / substitution for configure a switch (PCF)?
- platform: gpio
pin:
pcf8574: pcf8574_hub
number: 0
mode: ${pcf8575_bank_2_mode}
inverted: id(pcf_bank_1_invert)
This ${pcf8575_bank_2_mode} seemed to work, defined as substitution:
pcf8575_bank_1_mode: "OUTPUT"
This do not work I got “Boolean expected”, defined as global var, as substitution boolean doesn’t work either:
- id: pcf_bank_2_invert
type: boolean
restore_value: no
initial_value: 'true'
i tried the last one with all lambda syntaxes I know - without success.
How can i achieve this and as second, nice to have, can I do this from HA by toggling a switch - change from OUTPUT to INPUT and from invert: true to invert:false.
