Hey!
I’ve finally managed to get everything working. After it worked, I turned off the raspberry and later on again. Then I was only able to open the interface via my mobile app. Safari just loaded the whole time without actually showing the page. I turned it off again, waited a day and now it works again.
Only problem is that it doesn’t show the switches anymore (also didn’t on mobile yesterday). Any ideas how to fix this?
This is my config for the switches:
#Broadlink
switch:
platform: broadlink
host: 192.168.0.6
mac: ‘the mac address’
timeout: 15
switches:
tv:
friendly_name: “Hisense TV”
command_on: ‘JgBoAB4aHRo4HRscHBwcHBwcGxwcNx4aOBwcAAsNGxweGjgcHBwcHBwcGxwcHBw3Hho3HRwACwwcHBwbOB0cGxwcHBwcHBwbHDccHDgdGwALDRwcGxw4HRscHBwcHBwcGxwcNxwcOBwcAA0F’
command_off: ‘JgBoAB4aHRo4HRscHBwcHBwcGxwcNx4aOBwcAAsNGxweGjgcHBwcHBwcGxwcHBw3Hho3HRwACwwcHBwbOB0cGxwcHBwcHBwbHDccHDgdGwALDRwcGxw4HRscHBwcHBwcGxwcNxwcOBwcAA0F’
channel_1:
friendly_name: “Channel 1”
command_on: ‘JgA4AB4aHhk6Gx4ZHhoeGh4aHhoeGR4aHhoeNR4ACvIeGh4aORseGh4ZHxkeGh4aHhoeGR4aHjUeAA0F’
channel_2:
friendly_name: “ZDF”
command_on: ‘JgAaAB8ZHho6Gh4aHhoeGh4aHhkeGh4aHjU6AA0FAAAAAAAAAAAAAAAAAAA’
channel_3:
friendly_name: “Sat 1”
command_on: ‘JgBUAB4aHhk6Gx4ZHhoeGh4aHhoeGR4aHjUeGh4ACvIeGh4aOhoeGh4aHhoeGR4aHhoeGh41HhoeAAryHhoeGjkbHhoeGR4aHhoeGh4aHhkeNR4aHgANBQAAAAA=’
channel_4:
friendly_name: “RTL”
command_on: ‘JgBOAB4aOhseGR4aHhoeGh4aHhkeGh41OhoeAAsRHho6Gh8ZHhoeGh4aHhkeGh4aHjU6Gh4ACxEeGjkbHhoeGR4aHhoeGh4aHhkeNTobHgANBQAAAAAAAAAAAAA=’
channel_5:
friendly_name: “RTL2”
command_on: ‘JgA0AB4aOhoeGh4aHhoeGR8ZHhoeGh41OjUeAArzHho6Gh4aHhoeGh4ZHxkeGh4aHjU6NR4ADQUAAAAA’
channel_6:
friendly_name: “VOX”
command_on: ‘JgBOAB8aORseGh4ZHhoeGh4aHhoeGR41Hho6AAsPHho6Gx4ZHhoeGh4aHhoeGR4aHjUeGjoACw8eGjobHhkeGh4aHhoeGR4aHhoeNR4aOgANBQAAAAAAAAAAAAA=’
channel_7:
friendly_name: “Pro 7”
command_on: ‘JgA4AB8ZHho6Gh4aHhoeGh4ZHxkeGh41HhoeGR8ACvIeGh4aOhoeGh4aHhkeGh4aHhoeMiEZHxkeAA0F’
channel_8:
friendly_name: “ZDF Neo”
command_on: ‘JgAaAB4aHho6Gh4aHhkfGR4aHhoeNToaHhoeAA0FAAAAAAAAAAAAAAAAAAA=’
channel_9:
friendly_name: “kabel eins”
command_on: ‘JgA0AB8ZHxk6Gx4ZHhoeGh4aHhkfNDobHjUeAArxHhoeGjoaHhoeGh4aHhodGh41OhofNB8ADQUAAAAA’
light:
friendly_name: “Light”
command_on: ‘sg4yAAsXChcUDgsYChgLGBQOFA4KFwsXFQ4KGBQOFA4LGAoXCxgKGR4AAQcVDhQOCxcKGAoYAAAAAAAA’
command_off: ‘sg4yAAsXChcUDgsYChgLGBQOFA4KFwsXFQ4KGBQOFA4LGAoXCxgKGR4AAQcVDhQOCxcKGAoYAAAAAAAA’
color_switch:
friendly_name: “Color Switch”
command_on: ‘sgYyAAsXChcVDQsYChgKGBUOFA4LFwsXFA4KGBQOFA4UDgoYFA4LGB8AAQcVDhQOCxcLGAoYAAAAAAAA’
light_bulb:
friendly_name: “Light Bulb”
command_on: ‘sg0yAAoYCxcUDgsXCxgKGBQOFA4KFwsXFA0LGBQOFA4UDhQOChgKGR4AAQcVDhQOChgKGAoYAAAAAAAA’
command_off: ‘sg0yAAoYCxcUDgsXCxgKGBQOFA4KFwsXFA0LGBQOFA4UDhQOChgKGR4AAQcVDhQOChgKGAoYAAAAAAAA’
The logfile says this after restarting:
Thu Aug 09 2018 13:14:35 GMT+0200 (CEST)
Error while setting up platform broadlink
File “/usr/local/lib/python3.6/site-packages/homeassistant/helpers/entity_platform.py”, line 129, in _async_setup_platform
SLOW_SETUP_MAX_WAIT, loop=hass.loop)
File “/usr/local/lib/python3.6/asyncio/tasks.py”, line 358, in wait_for
return fut.result()
File “/usr/local/lib/python3.6/concurrent/futures/thread.py”, line 56, in run
File “/usr/local/lib/python3.6/site-packages/homeassistant/components/switch/broadlink.py”, line 157, in setup_platform
device_config.get(CONF_COMMAND_OFF)
File “/usr/local/lib/python3.6/site-packages/homeassistant/components/switch/broadlink.py”, line 193, in init
self._command_on = b64decode(command_on) if command_on else None
File “/usr/local/lib/python3.6/base64.py”, line 87, in b64decode
return binascii.a2b_base64(s)
binascii.Error: Incorrect padding
