Since PLMs are back in stock at the Insteon store, I think I’m gonna bite the bullet and switch from my fully-functional but periodically unstable Insteon hub to a PLM 2413U. I’m running HA on a Hardkernel ODROID-N2/N2+ and just want to be sure that once I plug the PLM USB into the server, I will be able to access it via the HA Integration, which is what I’m currently using with my Hub. I understand that I will likely need to manually connect all 51 (!) switches, dimmers, plugs, etc.
Any advice/tips would be appreciated.
