On save it immediately fails and log just says failed:
2021-03-12 08:51:32 ERROR (MainThread) [homeassistant.components.zwave_js.config_flow] Failed to set Z-Wave JS add-on config: Failed to set the Z-Wave JS add-on options
Any thoughts? I had 1.4 set up in config; commented it out, restarted multiple times. Retried a dozen+ times.
Open up the addon and verify that the configuration parameters are set to what you think they should be. Verify every letter of the usb path. Secondly, the usb path may be different. There’s a drop down and the available paths will be populated. You’ll most likely be using the device path instead of what you had before.
16:11:37.546 CNTRLR « [Node 016] CommandClass Manufacturer Proprietary has 1 endpoints
16:11:37.566 CNTRLR Multi Channel: Error after interview:
supportedCCs is not iterable
This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
TypeError: supportedCCs is not iterable
at new Endpoint (/usr/lib/node_modules/zwave-js/src/lib/node/Endpoint.ts:49:21)
at ZWaveNode.getEndpoint (/usr/lib/node_modules/zwave-js/src/lib/node/Node.ts:841:5)
at ZWaveNode.interviewCCs (/usr/lib/node_modules/zwave-js/src/lib/node/Node.ts:1433:26)
at ZWaveNode.interview (/usr/lib/node_modules/zwave-js/src/lib/node/Node.ts:1016:8)
at Driver.interviewNode (/usr/lib/node_modules/zwave-js/src/lib/driver/Driver.ts:895:10)
16:11:37.724 CNTRLR « [Node 004] received location:
16:11:37.726 CNTRLR [Node 004] MultilevelSwitchCC: doing a complete interview…
16:11:37.729 CNTRLR » [Node 004] requesting current switch state…
16:11:37.983 CNTRLR « [Node 006] is named “Front Hallway”
16:11:37.984 CNTRLR » [Node 006] retrieving node location…
[cont-finish.d] executing container finish scripts…
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
I have been trying to replace the old Zwave integration (thorugh configuration file) to Zwave JS. I deleted the lines in configuration file and deleted the integration.
When running the zwave JS plugin I get this error:
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] config.sh: executing...
[cont-init.d] config.sh: exited 0.
[cont-init.d] structure.sh: executing...
[cont-init.d] structure.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[21:59:31] INFO: Successfully send discovery information to Home Assistant.
21:59:41.464 DRIVER ███████╗ ██╗ ██╗ █████╗ ██╗ ██╗ ███████╗ ██╗ ███████╗
21:59:41.506 DRIVER version 6.5.0
21:59:41.509 DRIVER
ZWaveError: The config has not been loaded yet!
at ConfigManager.lookupSensorType (/usr/lib/node_modules/zwave-js/node_modules/@zwave-js/config/src/ConfigManager.ts:277:10)
at ConfigManager.lookupSensorScale (/usr/lib/node_modules/zwave-js/node_modules/@zwave-js/config/src/ConfigManager.ts:288:23)
at new MultilevelSensorCCReport (/usr/lib/node_modules/zwave-js/src/lib/commandclass/MultilevelSensorCC.ts:408:43)
at new CommandClass (/usr/lib/node_modules/zwave-js/src/lib/commandclass/CommandClass.ts:108:13)
at new MultilevelSensorCC (/usr/lib/node_modules/zwave-js/src/lib/commandclass/MultilevelSensorCC.ts:205:1)
at Function.from (/usr/lib/node_modules/zwave-js/src/lib/commandclass/CommandClass.ts:331:15)
at new ApplicationCommandRequest (/usr/lib/node_modules/zwave-js/src/lib/controller/ApplicationCommandRequest.ts:88:32)
at Function.from (/usr/lib/node_modules/zwave-js/src/lib/message/Message.ts:222:15)
at Driver.serialport_onData (/usr/lib/node_modules/zwave-js/src/lib/driver/Driver.ts:1395:18)
at SerialAPIParser.emit (events.js:315:20)
[cont-finish.d] executing container finish scripts...
Exactly the same error yesterday after updating to 1.11, I had to rollback.
I have great doubts about 1.11, can someone confirm that 1.12 will correct this??
I personally do not recommend installing 1.11, spending lot of time to restore to 1.10. Shouldn’t be a good idea to remove 1.11 while a correction is made? Just for others…
Ok, meanwhile Martin, a developer of the plugin decided to block me from the github because I just say that I had the same problem. Kindergarten. Now as I wrote an email to him I’m afraid I will be banned from this forum too… Bye.
I have a schlage door lock. It was connected to my previous setup via secure node. I added the network key into zwave js but for some reason it doesn’t load my schlage node. It’s there but as uknown.
I tried to remove the schlage node via the zwave js integration but it fails to remove it…Was going to re-add it afterwards.
