I have a sonoff Touch (1 Button) Runing tasmota
And a TP-LINK B100 Bulb
The bulb is added in home assistant
And I have the sonoff switch in-place of the switch that turns the bulb on/off
But … The bulb is smart so it dosen’t need a smart switch
But I put the switch there in case someone wanted to use a switch and not just voice control or phone control
The problem is When someone turns the switch off that also turns the bulb completly off
And that disables all the automations I set for the bulb
So is there a way to make the tasmota sonoff touch
be turned on/off without truning the bulb on/off with it
Instead I’d make that an automation in Home Assistant
