Switching to Z-Wave JS UI with Schlage BE469ZP Locks
Hi All,
I currently run Z-Wave JS with 4 Schlage BE469ZP locks which are all on the ground floor around my family room which is where my HUSBZB-1 stick is. I would like to try Z-Wave JS UI, I do not mind starting from scratch so I was going to exclude all 4 of my locks, factory reset them and then remove the Z-Wave JS add-on. Do I need to copy all of the security keys in the Z-Wave JS configuration or is it just a case of generating new ones with the new UI?
The other question is does anyone know if my Z-Wave stick will work OK with Z-Wave JS UI? I know the HSUSBZB-1 is a little long in the tooth but I have not had any issues with it.
Thanks in advance
Good morning,
Thank you for the reply. I have read through that thread, to be honest I would rather start again from scratch as I only have the 4 Z-Wave devices. Over the last year I had a Z-Wave motion sensor & a plug go bad and my network has been a little flaky even though I tried several times to rebuild the node routes, I figured now might be a good opportunity to start fresh.
Then if you’re starting over you don’t need anything, security keys or otherwise, from the previous installation.
Perfect,
Thank you
