Switching zigbee coordinator dongles
hey forum,
If I’m switching my coordinator , do I need to basically recreate my entire zigbee network and set up all the connections again? Or no? I use Z2M add on with in HA
it depends on which coordinator you use, Smlight coordinators you can flash IEEE from old to new with the same settings. not always this works though and all zigbee devices have to be repaired again. I previously moved from Smlight slzb-06M to 06MG24 without major problems
