I recently installed some Sylvania Lightify Recessed fixtures. I added them to my Smartthings Hub, which is connected to HA using the Smartthings MQTT Bridge. The lights work fine in the ST app.
I sort of have them working using the code below, but have a couple issues. First, when choosing a color from the color wheel, the lights do not change. Second issue is when I the white level, it is appears to be a different scale on HA, only 150-500, not the 2700-6500 I’d expect
To be honest I really only got this far by copying other examples, so if you see something in the code below that makes no sense, it is only because I don’t quite understand all this yet…
light 6:
platform: mqtt
name: "Rear Right Recessed"
state_topic: "smartthings/Rear Right Recessed/switch"
command_topic: "smartthings/Rear Right Recessed/switch"
state_value_template: "{{ value_json.state }}"
brightness_state_topic: "smartthings/Rear Right Recessed/level"
brightness_command_topic: "smartthings/Rear Right Recessed/level"
brightness_value_template: "{{ value_json.brightness }}"
hs_state_topic: "smartthings/Rear Right Recessed"
hs_command_topic: "smartthings/Rear Right Recessed"
hs_value_template: "{{ value_json.rgb | join(',') }}"
color_temp_state_topic: "smartthings/Rear Right Recessed/colorTemperature"
color_temp_command_topic: "smartthings/Rear Right Recessed/colorTemperature"
color_temp_value_template: "{{ (1000000/float(value)) | int }}"
hs: true
qos: 0
payload_on: "on"
payload_off: "off"
retain: true
google_assistant: false
MQTT traffic generated from the Smartthings App:
smartthings/Rear Right Recessed/switch on
smartthings/Rear Right Recessed/level 50
smartthings/Rear Right Recessed/colorTemperature 6494
For color, it sends the following back to back…
smartthings/Rear Right Recessed/hue 81
smartthings/Rear Right Recessed/saturation 77
MQTT traffic generated from the HA code above.
smartthings/Rear Right Recessed/switch on - Good
smartthings/Rear Right Recessed/level 17 - Good
smartthings/Rear Right Recessed 270.0,100.0 - Colors not in the same Hue/Saturation format. Not sure how to fix this…
smartthings/Rear Right Recessed/colorTemperature 441 - Scale is off. HA uses mired scale, so while the commands work, they aren’t really changing anything
Also, I haven’t done anything with regards to the templates, and I’m sure they are messed up.
Thanks!
