I have a WWCW LED strip which I would like to control at constant brightness, as specified in Cold White + Warm White Light — ESPHome
I wonder whether it’s possible to set ESPhome to not overlap the PWM “on” states, so that once one turn off, the other turns on.
So, not to do
WW |+++-------|+++-------|+++-------| ...
CW |+++++++---|+++++++---|+++++++---| ...
but
CW |---+++++++|---+++++++|---+++++++| ...
The same applies to partial power levels, obviously, just the end of the second “on” state won’t reach the end of the PWM period.
This would help the power supply by reducing the total load, and I can pick (or resue) a power supply which has a power rating of one led strip, instead of one able to provide power to both at the same time.
