Synology Container Manager
Ever since 2023.7.0 when HomeAssistant announced:
Blockquote
If you use the Home Assistant Container installation method, for example, using Docker, please make sure you are using our official (multi-platform) images.
The correct and preferred image to use for our stable releases is:
ghcr.io/home-assistant/home-assistant:stable
Although not the preferred location by the Home Assistant project, the image is also available on DockerHub:
homeassistant/home-assistant:stable
The update notification in Synology’s new Container Manager (f/k/a Docker) stopped notifying of the arrival of updates. I am on 2023.7.2 and it will not notify me of the existence of 2023.7.3.
Hello
Same problem. Is there any way to change the image source without to break my existing Home Assistant? I’d like to change it for ghcr.io but am afraid and don’t know at all how to do it (I use pertained on a synology NAS).
