Synology DSM configuration.yaml integration
I just recently connected a Synology NAS to my network and have been working on the integration. The ui integration works flawlessly, but it seems to be missing a bunch of sensors (disk temp, etc). I’m trying to add the configuration via yaml, but am hung up on one spot in particular - how to add the monitored conditions. I’ve read that before the latest breaking changes, the configuration variable was monitored_conditions, but that’s been deprecated. What in the heck is it now?
This is what I have (and it doesn’t work, at all):
synology_dsm:
  ssl: true
  host: 192.168.x.x
  port: 5001
  username: !secret nas_username
  password: !secret nas_password
  monitored_conditions:
  - cpu_total_load
  - memory_real_usage
  - memory_size
  - memory_cached
  - memory_available_swap
  - memory_available_real
  - memory_total_swap
  - memory_total_real
  - network_up
  - network_down
  - volume_status
  - volume_percentage_used
  - volume_disk_temp
  - volume_size_total
  - volume_disk_temp_avg
  - volume_disk_temp_max
  - disk_name
  - disk_status
  - disk_smart_status
  - disk_temp
  - security_status
Nevermind. I tried the UI config again and it worked exactly as designed. Not sure what was up with it before.
