I have a “Synology DSM” NAS box, and HomeAssistant helpfully monitors status/disk usage/etc. Well, at least it used to.
Now it no longer works. All of the entities are broken, and if I go to the integration in Home Assistant, there is a big orange “Needs Attention” box that says:
Every minute or so it tries to re-initialize and then returns to the error.
If I click on the cogwheel, I get a popup error that “Config flow could not be loaded: 500 Internal Server Error Server got itself in trouble”.
I’ve seen a few other posts about this error text (in connection with different integrations), but they seem to be a few years old and reference a “SmartThings” issue but I do not – to the best of my knowledge – use SmartThings.
@jeffcrum Sure but this doesn’t appear to be an issue with reachability of the NAS box… the settings screen that even LETS ME CHANGE THE HOSTNAME is crashing, presumably because of some sort of bug in the integration itself… So even if I wanted to replace the XXXX.hostname with its static IP, I do not appear to have a way to do so…
Update I was able to “Add” it again after restarting HA
I just ran into the same problem. Unpacked Home Assistant Green, started for the first time. Clicked “Add” on Discovered Synology and logged in.
It then asked me to select the location for the Backup, then I closed the tab (by accident) to go to my Synology and configure another shared folder. Then opened Home Assistant UI again and clicked “Add”.
Now I’m seeing the same error message as people in this thread:
It seems like there’s maybe some corrupted data being written if the configuration process for the backup location isn’t finished?
