Synology RackStation "Connection failed"
When trying to connect my Synology RackStation manually via the UI, it seems HASS reaches the IP of the RackStation, but can’t reach the System. When trying connect following error shows up “Connection failed”.
In the log, following entry’s are made every time:
Logger: homeassistant.components.synology_dsm.config_flow
Source: components/synology_dsm/config_flow.py:215
Integration: synology_dsm (Dokumentation, Probleme)
{'api': None, 'code': -1, 'reason': 'Unknown', 'details': "ClientConnectorError = ConnectionKey(host='192.168.178.150', port=5001, is_ssl=True, ssl=True, proxy=None, proxy_auth=None, proxy_headers_hash=None)"}
{'api': None, 'code': -1, 'reason': 'Unknown', 'details': "ClientConnectorError = ConnectionKey(host='192.168.178.150', port=5000, is_ssl=False, ssl=True, proxy=None, proxy_auth=None, proxy_headers_hash=None)"}
{'api': None, 'code': -1, 'reason': 'Unknown', 'details': "ClientConnectorDNSError = ConnectionKey(host='rackstation', port=5000, is_ssl=False, ssl=True, proxy=None, proxy_auth=None, proxy_headers_hash=None)"}
{'api': None, 'code': -1, 'reason': 'Unknown', 'details': "ClientConnectorDNSError = ConnectionKey(host='rackstations', port=5000, is_ssl=False, ssl=True, proxy=None, proxy_auth=None, proxy_headers_hash=None)"}
{'api': None, 'code': -1, 'reason': 'Unknown', 'details': "ClientConnectorError = ConnectionKey(host='192.168.178.155', port=5000, is_ssl=False, ssl=True, proxy=None, proxy_auth=None, proxy_headers_hash=None)"}
