Hi
Would like to add two Synology NAS-stations to HA. It seems, that the SynologyDSM Sensor can handle only one?
Has anyone successfully added more than one discstation?
Hi
I dont have 2 of them, but i think you could just add an other sensor?
- platform: synologydsm
host: 192.168.0.XXX
port: 5000
username: !secret Synology_UN
password: !secret Synology_PW
monitored_conditions:
- cpu_total_load
- memory_real_usage
- network_up
- network_down
- volume_disk_temp_avg
- volume_percentage_used
- platform: synologydsm2
host: 192.168.0.XXX
port: 5000
- cpu_total_load
- memory_real_usage
- network_up
- network_down
Had not tried to add a platfom called synologydsm2.
Did not work:
Failed config
General Errors:
- Platform not found: sensor.synologydsm2
Successful config (partial)
Thanks for the idea.
Adding
Sensor2:
Not sure what you mean?
host: 192.168.0.XXX
port: 5000
- cpu_total_load
- memory_real_usage
- network_up
- network_down
Sensor2:
host: 192.168.0.XXX
port: 5000
- cpu_total_load
- memory_real_usage
- network_up
- network_down
Ah
Good thinking - but it did not work.
Failed config
General Errors:
- Component not found: sensor2
- Setup failed for sensor2: Component not found.
I dont think it is possible.
That sucks…
There must be a way!
our family have two synology NAS in the local network. I managed to get them to work. I have other issues, but I have gotten further than anyone else on this thread.
Here is my setup
host: local_ip_1
username: user1
password: password1
- network_down
host: local_ip_2
username: user2
password: password2
- network_down
