hello,
I have this switch
switch:
- platform: command_line
switches:
arest_pin_four:
command_on: "/usr/bin/curl -X GET http://192.168.1.201/control?cmd=gpio,12,1"
command_off: "/usr/bin/curl -X GET http://192.168.1.201/control?cmd=gpio,12,0"
command_state: "/usr/bin/curl -X GET http://192.168.1.201/control?cmd=status,gpio,12"
value_template: ' {{ ('{"log":"","plugin":1,"pin":12,"mode":"output","state":"1"}'|from_json).state == "1" }} '
from the Template Developer Tool the value_template is resolved correctly into a TRUE, while I get a syntax error when I put the code into configuration.yaml. What am I doing wrong?
