Probably a silly question but where is the syslog? Specifically, where do the notifications for these end up?
It depends on your operating system. The integration writes to your OS syslog.
I thought so. I’m on HASS OS and I checked this log and I got nada.
Is that the host syslog though, or some home assistant host log (I don’t know)?
I think it is? Lots of this…
[167604.067546] ext4 filesystem being remounted at /run/systemd/unit-root/etc/modprobe.d supports timestamps until 2038 (0x7fffffff)
[167604.067561] ext4 filesystem being remounted at /run/systemd/unit-root/etc/dropbear supports timestamps until 2038 (0x7fffffff)
[167604.067580] ext4 filesystem being remounted at /run/systemd/unit-root/etc/hosts supports timestamps until 2038 (0x7fffffff)
[167604.067617] ext4 filesystem being remounted at /run/systemd/unit-root/etc/docker supports timestamps until 2038 (0x7fffffff)
[167604.067632] ext4 filesystem being remounted at /run/systemd/unit-root/etc/hostname supports timestamps until 2038 (0x7fffffff)
[167633.741662] audit: type=1334 audit(1644883186.387:433): prog-id=96 op=UNLOAD
[167633.741943] audit: type=1334 audit(1644883186.387:434): prog-id=95 op=UNLOAD
[167634.369948] audit: type=1334 audit(1644883187.015:435): prog-id=98 op=UNLOAD
[167634.369964] audit: type=1334 audit(1644883187.015:436): prog-id=97 op=UNLOAD
