Hi folks
I figured out that when I deploy too many of the template sensors below the system gets first very unstable (when deploying about 5-10) and then crashes all the time (when deploying more than 10). As soon as I deactivate enough sensors the system gets back operational as if nothing happened.
So I assume its either a) system related or my template sensors are b) poorly written (I’m definetly not a pro )
Goal of the whole thing is to have specific “Problem”-Sensors per Room and also per Problem Category so I can use them in Lovelace and also for reporting as text-to-speech.
To get that I’m at the stage where I need a sensor like the one below per Room/Level and House but also a “count” of that same result, since I cannot use the same template to do both (but maybe I’m wrong here). If I count that correctly I would have to deploy about 40 of them (1x 20 to get the sensor with text and 1x 20 to get the sensor count) which would definitely be overload as it stands now.
I assume that something which would help a lot is not iterating over all binary sensors severall times, just the ones of interest: beginning with
- binary_sensor.problem*
- binary_sensor.climate*
but I do not know how to convert the “states.binary_sensor” part into a working “states.binary_sensor.problem*” thing…
Or maybe there is a totally different idea around here how to filter several sensors by entity_id-Beginning and labels?
So any help in either pointing me into the right direction or optimizing the template would be appreciated.
Current setup:
HassOS direct on Beelink S12 pro with 16GB RAM and 512GB SSD
Core: 2025.1.4
Supervisor: 2025.02.1
Operating System: 14.2
Frontend: 20250109.2
Same behaviour tested and occurs with Core 2025.2.3
Here is the code:
{# create list to exclude #}
{% set label = label_entities('to_be_installed') %}
{% set exclude = states.binary_sensor | selectattr('entity_id', 'in', label)
| map(attribute='entity_id') | list %}
{# create list to ignore for display #}
{% set label = label_entities('problem_exclude') %}
{% set exclude_disp = states.binary_sensor | selectattr('entity_id', 'in', label)
{# create list to include #}
{% set label = label_entities('problem_gets_critical_when_nobody_home') %}
{% set include = states.binary_sensor | selectattr('entity_id', 'in', label)
{# create list of binary_sensors to check, exlude level changes on occupancy #}
{% set labeltype = label_entities('problem_house') %}
{% set labellevel = label_entities('problem_critical') %}
{% set labelleveldrop_a = label_entities('problem_gets_info_when_nobody_home') %}
{% set labelleveldrop_b = label_entities('problem_gets_important_when_nobody_home') %}
{% set list = states.binary_sensor | expand()
| selectattr('entity_id', 'in', labeltype)
| selectattr('entity_id', 'in', labellevel)
| rejectattr('entity_id', 'in', labelleveldrop_a)
| rejectattr('entity_id', 'in', labelleveldrop_b)
{# add includes #}
{% set list = list + include %}
{# exlude not installed and to ignore from displaying #}
{% set list = expand(list)
| rejectattr('entity_id', 'in', exclude)
| rejectattr('entity_id', 'in', exclude_disp)
{# check for state #}
| selectattr('state', 'eq', 'on')
| map(attribute='entity_id') | sort | reverse | list %}
{# swap entity_id with friendly name #}
| map(attribute='attributes.friendly_name') | list %}
{# if list is very long... #}
{% if list | count > 10 -%}Es gibt {{ list |count }} kritische Probleme, diese solltest du schnellstmöglich beheben.
{# if list NOT empty... #}
{% elif list | count > 0 -%}Kritische Probleme solltest du schnellstmöglich beheben, und zwar:
{# if list is NOT empty then create readable output. #}
{%- if list | count > 2 -%}
{% for item in list -%}
{% if loop.revindex == 2 -%}{{ item }} {% elif loop.last -%} und {{ item }}. {% else -%}{{ item }}, {% endif -%}{% endfor -%}
{% elif list | count == 2 %}{% for item in list -%}{% if loop.last -%} und {{ item }}. {% else -%}{{ item }} {% endif -%}{% endfor -%}
{% elif list | count == 1 %}{% for item in list -%}{{ item }}.{% endfor -%}
{% endif %}
{# if list IS empty... #}
{% else %}none
{% endif %}
