Riga-14
(Riga 14)
1
im updateing Home Assistant Operating System Update and its installing restarting and saying not updated.
OS Ver:14.2
OS Ver Update: 15.1
[core-ssh ~]$ ha os info
board: rpi5-64
boot: A
boot_slots:
A:
state: booted
status: good
version: "14.2"
B:
state: inactive
status: bad
version: "15.1"
data_disk: TOSHIBA-MQ04UBD200-299DT52JT
update_available: true
version: "14.2"
version_latest: "15.1"
francisp
(Francis)
2
You need to boot with Raspberry OS, and run a firmware update. Then HA OS 15.1 can be installed.
francisp
(Francis)
4
I know. But HA OS can’t update the firmware. So, you need to boot with Raspberry OS, and run a firmware update. Then HA OS 15.1 can be installed.
Riga-14
(Riga 14)
5
I install raspberry pi os on the sd card
francisp
(Francis)
6
Yes, and update the firmware.
Riga-14
(Riga 14)
7
i run ha on the hard drive that i moved from the sd card would it still boot?
