I am running a remote HAOS that connects home with wireguard client, this works nicely.
But, I mount a volume from my home server over the VPN which is ofc not available at boot.
So, I though to use the System Monitor 's IPV4 Address of wg0 state change to trigger an automation to re-mount. So far, so good.
Sadly it seems that the System Monitor ignores the wg0 interface as it probably does not exist at boot…and alas, the automation never triggers.
If I reload the System Monitor it updates correctly, if I afterwards take the interface down and up again it triggers as it should, but not at boot.
Anyone have any ideas?
Regards
Morten
