System monitor load sensor generating a lot of logbook entries
I have several sensors set up with thesystem monitor sensor platform.
For some reason, the load sensors generate a lot of logbook entries. I am not sure why this is the case. The other sensors from that platform do not seem to do this at all.
I haven’t yet searched how to suppress these events from the logbook, and I’m quessing it is relatively easy to do that.
But I don’t think they should be there in the first place.
Is this a bug or intended behavior?
Screenshot:
Which core version are you using?
Here’s all the version info:
Home Assistant Core 2022.5.5
Home Assistant Supervisor 2022.05.3
Home Assistant OS 8.1
Kernel version 5.15.32-v8
Agent version 1.2.1
The step between the logbook entries seems to be 10 to 20 minutes if that helps.
This should be fixed in 2022.6 which will be released next Wednesday, or you can try the core beta version now. It’s very stable.
Thanks a lot, good to know it’s being fixed!
I’m quite a newbie still and don’t know how to do the beta update, and I’m fine with knowing the issue is fixed.
I will most likely beta test at some point as I get more accustomed to HA!
