System Monitoring - How does yours look?
Thank you. Much appreciated.
Nice to know, the GPU is an on-chip graphics processing unit (GPU) according to Wikipedia so temps are always going to be pretty much the same.
I’m using glances and HA dockermon.
- platform: glances
  host: localhost
  version: 3
  resources:
    - 'disk_use'
    - 'disk_use_percent'
    - 'disk_free'
    - 'cpu_temp'
    - 'processor_load'
    - 'memory_use'
    - 'memory_use_percent'
    - 'memory_free'
    - 'docker_active'
    - 'docker_cpu_use'
    - 'docker_memory_use'
Relevant thread I found very helpful.
Edit. Just realized @klogg already posted in this thread!
I found glances to be very useful to monitor which addons were dogging the system on Hassio. It’s also the only way I’ve found to get the CPU temp with Hassio on an RPi. I don’t run it all the time though because I found it tended it be a bit of a resource hog itself.
configuration file: https://github.com/Limych/HomeAssistantConfiguration/blob/master/lovelace/30_system_info_view.yaml
I stand corrected thanks @klogg. This works with no muss, no fuss.
  - platform: command_line
    name: RPi CPU Temperature
    command: "cat /sys/class/thermal/thermal_zone0/temp"
    value_template: "{{ value | multiply(0.001) | round(2) }}"
@cwhits what is the yaml code for locking the service on the right side of your card?
@ghvader
Allow me…
It is the toggle-lock-entity-row - GitHub - thomasloven/lovelace-toggle-lock-entity-row
Look at some of @thomasloven other cards, they are all excellent.
It’s a pleasure, I wish I could say it was my idea… I forget now who I got that from.
Can you share the sensors as well :slight_smile:?
Also, where do you save the Rpi and HA uptime?
@Yoinkz
#=== Sensors
  #=== Latest Sonoff Tasmota firmware version
    name: Tasmota Current Version
    command: "curl -s https://github.com/arendst/Sonoff-Tasmota/releases/latest | cut -d'\"' -f2 | rev | cut -d'/' -f1 | rev"
    scan_interval: 86400
  #=== Installed hass.io version
  - platform: version
    source: local
  #=== Latest Available HA Version
  - platform: version
    name: Latest Available Version
    beta: false
    image: raspberrypi3
    source: hassio
  #=== Raspberry Pi Power
  - platform: rpi_power
    text_state: True
  #=== Last boot time, Disk, memory & CPU usage
  - platform: systemmonitor
    resources:
      - type: last_boot
      - type: disk_use_percent
        arg: /
      - type: memory_use_percent
      - type: processor_use
  #=== CPU Temperature
    unit_of_measurement: "°C"
    value_template: '{{ value | multiply(0.001) | round(0) }}'
  #=== System Up Time
  - platform: uptime
    sensors:
      #=== Home Assistant uptime
      ha_uptime:
        friendly_name: HA Uptime
        value_template: >
          {% if states('sensor.uptime') == '0.0' %}
            Just restarted...
          {% else %}
            {% macro phrase(value, name) %}
            {%- set value = value | int %}
            {%- set end = 's' if value > 1 else '' %}
            {{- '{} {}{}'.format(value, name, end) if value | int > 0 else '' }}
            {%- endmacro %}
            {% set weeks = (states('sensor.uptime') | int / 7) | int %}
            {% set days = (states('sensor.uptime') | int) - (weeks * 7) %}
            {% set hours = (states('sensor.uptime') | float - states('sensor.uptime') | int) * 24 %}
            {% set minutes = (hours - hours | int) * 60 %}
            {{ [ phrase(weeks, 'week'), phrase(days, 'day'), phrase(hours, 'hr'), phrase(minutes, 'min') ] | select('!=','') | list | join(', ') }}
          {% endif %}
      #=== Raspberry Pi last boot date and time
      last_boot_date_time:
        friendly_name: Last Boot
        value_template: >
          {% set date = as_timestamp(states('sensor.last_boot')) | timestamp_custom('%d') %}
          {% set date = '{:01}'.format(date | int) %}
          {% if date in ('1', '21', '31') %}
            {% set date = date ~ 'st' %}
          {% elif date in ('2', '22') %}
            {% set date = date ~ 'nd' %}
          {% elif date in ('3', '23') %}
            {% set date = date ~ 'rd' %}
          {% else %}
            {% set date = date ~ 'th' %}
          {% endif %}
          {{ as_timestamp(states('sensor.last_boot')) | timestamp_custom('%H:%M on %a') }} {{ date }} {{ as_timestamp(states('sensor.last_boot')) | timestamp_custom('%b %Y') }}
      #=== Raspberry Pi Up Time
      rpi_uptime:
        friendly_name: RPi Uptime
        entity_id: sensor.time
        value_template: >
          {% set up_time = as_timestamp(now()) - as_timestamp(states('sensor.last_boot')) %}
          {% set minutes = (up_time // 60) | int %}
          {% set hours = (minutes // 60) %}
          {% set days = (hours // 24) %}
          {% set weeks = (days // 7) %}
          {% set minutes = (minutes % 60) %}
          {% set hours =  (hours % 24) %}
          {% set days = (days % 7) %}
                    {%- set value = value %}
          {%- endmacro %}
          {% set text = [ phrase(weeks, 'week'), phrase(days, 'day'), phrase(hours, 'hr'), phrase(minutes, 'min') ] | select('!=','') | list | join(', ') %}
          {% set last_comma = text.rfind(',') %}
          {% if last_comma != -1 %}
            {% set text = text[:last_comma] + ' and' + text[last_comma + 1:] %}
          {% endif %}
          {{ text }}
How did you do your component count? Thats a great idea
EDIT: A much better way, courtesy of @petro is further down this thread.
Here --> System Monitoring - How does your look?
#=== Home Assistant Component counts
    sensors:
    #----- Count Automations
      count_automations:
        entity_id: sensor.date
        value_template: >
          {%- set domains = ['automation'] -%}
          {%- for domain in domains -%}
            {%- for item in states[domain] -%}
              {% if loop.first %}
                {{loop.length}}
              {% endif %}
            {%- endfor -%}
          {%- endfor -%}
    #----- Count Scripts
      count_scripts:
        value_template: >
          {%- set domains = ['script'] -%}
              {% if loop.first %}
                {{loop.length}}
              {% endif %}
            {%- endfor -%}
          {%- endfor -%}
    #----- Count Device Trackers
      count_device_trackers:
        value_template: >
          {%- set domains = ['device_tracker'] -%}
              {% if loop.first %}
                {{loop.length}}
              {% endif %}
            {%- endfor -%}
          {%- endfor -%}
    #----- Count Binary Sensors
      count_binary_sensors:
        value_template: >
          {%- set domains = ['binary_sensor'] -%}
              {% if loop.first %}
                {{loop.length}}
              {% endif %}
            {%- endfor -%}
          {%- endfor -%}
    #----- Count Sensors
      count_sensors:
        value_template: >
          {%- set domains = ['sensor'] -%}
              {% if loop.first %}
                {{loop.length}}
              {% endif %}
            {%- endfor -%}
          {%- endfor -%}
    #----- Count Switches
      count_switches:
        value_template: >
          {%- set domains = ['switch'] -%}
              {% if loop.first %}
                {{loop.length}}
              {% endif %}
            {%- endfor -%}
          {%- endfor -%}
    #----- Count Zones
      count_zones:
        value_template: >
          {%- set domains = ['zone'] -%}
              {% if loop.first %}
                {{loop.length}}
              {% endif %}
            {%- endfor -%}
          {%- endfor -%}
    #----- Input Booleans
      count_input_booleans:
        value_template: >
          {%- set domains = ['input_boolean'] -%}
              {% if loop.first %}
                {{loop.length}}
              {% endif %}
            {%- endfor -%}
          {%- endfor -%}
    #----- Input Numbers
      count_input_numbers:
        value_template: >
          {%- set domains = ['input_number'] -%}
              {% if loop.first %}
                {{loop.length}}
              {% endif %}
            {%- endfor -%}
          {%- endfor -%}
    #----- Input Texts
      count_input_texts:
        value_template: >
          {%- set domains = ['input_text'] -%}
              {% if loop.first %}
                {{loop.length}}
              {% endif %}
            {%- endfor -%}
          {%- endfor -%}
    #----- Input Selects
      count_input_selects:
        value_template: >
          {%- set domains = ['input_select'] -%}
              {% if loop.first %}
                {{loop.length}}
              {% endif %}
            {%- endfor -%}
          {%- endfor -%}
    #----- Input Date Times
      count_input_datetimes:
        value_template: >
          {%- set domains = ['input_datetime'] -%}
              {% if loop.first %}
                {{loop.length}}
              {% endif %}
            {%- endfor -%}
          {%- endfor -%}
Your memory usage if quite low compared to mine, are you using the free command to get memory usage or some other way?
@klogg
Thanks - much appreciated !
No, not as far as I know! I am running hassio on an RPi3 so even if I new Linux I wouldn’t be able to run any native commands.
Gives me this error:
Platform not found: sensor.rpi_power
you’ll have to install the component manually
:wink: Thanks!
What about your icons (customize.yaml)?
