Hello, NodeRed is restarting every 30’ more or less. This is the log. I have read several topics but didn’t find a way to fix it. I think it is all related with the System time, but no idea how to fix it:
probably is too much info, but just in case:
4 Mar 10:52:10 - [info] [cronplus:6 de diciembre] Refreshing running schedules
4 Mar 10:52:10 - [info] [cronplus:8 de diciembre] System Time Change Detected!
4 Mar 10:52:10 - [info] [cronplus:8 de diciembre] Refreshing running schedules
4 Mar 10:52:10 - [info] [cronplus:25 de diciembre] System Time Change Detected!
4 Mar 10:52:10 - [info] [cronplus:25 de diciembre] Refreshing running schedules
4 Mar 10:52:10 - [info] [cronplus:f4e011d82552b281] System Time Change Detected!
4 Mar 10:52:10 - [info] [cronplus:f4e011d82552b281] Refreshing running schedules
4 Mar 10:52:10 - [info] [cronplus:f4e011d82552b281] createTask - index: 0, static: true, opt: {"name":"schedule1","topic":"topic1","payloadType":"default","payload":"","expressionType":"solar","expression":"0 * * * * * *","location":"40.5000244367571, 0.49804377587086346","offset":"0","solarType":"selected","solarEvents":"civilDusk","type":"date"}
4 Mar 10:52:10 - [info] [cronplus:Sunrise -20'] System Time Change Detected!
4 Mar 10:52:10 - [info] [cronplus:Sunrise -20'] Refreshing running schedules
4 Mar 10:52:10 - [info] [cronplus:Sunrise -20'] createTask - index: 0, static: true, opt: {"name":"schedule1","topic":"topic1","payloadType":"default","payload":"","expressionType":"solar","expression":"*/5 7-11 * * *","location":"40.5000244367571 0.49804377587086346","offset":"-20","solarType":"selected","solarEvents":"sunrise","type":"date"}
4 Mar 10:52:10 - [info] [cronplus:a y 20 y 40' de 10 a 20 L-V] System Time Change Detected!
4 Mar 10:52:10 - [info] [cronplus:a y 20 y 40' de 10 a 20 L-V] Refreshing running schedules
4 Mar 10:52:10 - [info] [cronplus:L-V 18:00] System Time Change Detected!
4 Mar 10:52:10 - [info] [cronplus:L-V 18:00] Refreshing running schedules
4 Mar 10:52:52 - [info] [cronplus:/20' - 1.0] System Time Change Detected!
4 Mar 10:52:52 - [info] [cronplus:/20' - 1.0] Refreshing running schedules
4 Mar 10:52:52 - [info] [cronplus:X:30' entre [7-17) L-V] System Time Change Detected!
4 Mar 10:52:52 - [info] [cronplus:X:30' entre [7-17) L-V] Refreshing running schedules
4 Mar 10:52:52 - [info] [cronplus:X:45' entre [7-17) L-V] System Time Change Detected!
4 Mar 10:52:52 - [info] [cronplus:X:45' entre [7-17) L-V] Refreshing running schedules
4 Mar 10:52:52 - [info] [cronplus:c/5' entre [8-17) L-V] System Time Change Detected!
4 Mar 10:52:52 - [info] [cronplus:c/5' entre [8-17) L-V] Refreshing running schedules
4 Mar 10:52:52 - [info] [cronplus:X:55' entre [07-17) L-V] System Time Change Detected!
4 Mar 10:52:52 - [info] [cronplus:X:55' entre [07-17) L-V] Refreshing running schedules
4 Mar 10:52:52 - [info] [cronplus:Viernes a las 18:00] System Time Change Detected!
4 Mar 10:52:52 - [info] [cronplus:Viernes a las 18:00] Refreshing running schedules
4 Mar 10:52:52 - [info] [cronplus:X:50' entre [7-17 L-V] System Time Change Detected!
4 Mar 10:52:52 - [info] [cronplus:X:50' entre [7-17 L-V] Refreshing running schedules
4 Mar 10:52:52 - [info] [cronplus:e655dff5947e57da] System Time Change Detected!
4 Mar 10:52:52 - [info] [cronplus:e655dff5947e57da] Refreshing running schedules
4 Mar 10:52:52 - [info] [cronplus:b100698d70690f9d] System Time Change Detected!
4 Mar 10:52:52 - [info] [cronplus:b100698d70690f9d] Refreshing running schedules
4 Mar 10:52:52 - [info] [cronplus:Sol en lo alto -90'] System Time Change Detected!
4 Mar 10:52:52 - [info] [cronplus:Sol en lo alto -90'] Refreshing running schedules
4 Mar 10:52:52 - [info] [cronplus:Sol en lo alto -90'] createTask - index: 0, static: true, opt: {"name":"schedule1","topic":"topic1","payloadType":"default","payload":"","expressionType":"solar","expression":"0 * * * * * *","location":"51.025, -1.4","offset":"-90","solarType":"selected","solarEvents":"solarNoon","type":"date"}
4 Mar 10:52:52 - [info] [cronplus:Sol en lo alto -25'] System Time Change Detected!
4 Mar 10:52:52 - [info] [cronplus:Sol en lo alto -25'] Refreshing running schedules
4 Mar 10:52:52 - [info] [cronplus:Sol en lo alto -25'] createTask - index: 0, static: true, opt: {"name":"schedule1","topic":"topic1","payloadType":"default","payload":"","expressionType":"solar","expression":"0 * * * * * *","location":"51.025, -1.4","offset":"-25","solarType":"selected","solarEvents":"solarNoon","type":"date"}
4 Mar 10:52:52 - [info] [cronplus:/5' de 7 a 12 am] System Time Change Detected!
4 Mar 10:52:52 - [info] [cronplus:/5' de 7 a 12 am] Refreshing running schedules
4 Mar 10:52:52 - [info] [cronplus:Atardecer empieza -30] System Time Change Detected!
4 Mar 10:52:52 - [info] [cronplus:Atardecer empieza -30] Refreshing running schedules
4 Mar 10:52:52 - [info] [cronplus:Atardecer empieza -30] createTask - index: 0, static: true, opt: {"name":"schedule1","topic":"topic1","payloadType":"default","payload":"","expressionType":"solar","expression":"0 * * * * * *","location":"40.5000244367571 0.49804377587086346","offset":"-30","solarType":"selected","solarEvents":"eveningGoldenHourStart","type":"date"}
4 Mar 10:52:52 - [info] [cronplus:Sunset] System Time Change Detected!
4 Mar 10:52:52 - [info] [cronplus:Sunset] Refreshing running schedules
4 Mar 10:52:52 - [info] [cronplus:Sunset] createTask - index: 0, static: true, opt: {"name":"schedule1","topic":"topic1","payloadType":"default","payload":"","expressionType":"solar","expression":"0 * * * * * *","location":"40.5000244367571, 0.49804377587086346","offset":"0","solarType":"selected","solarEvents":"sunset","type":"date"}
4 Mar 10:52:52 - [info] [cronplus:Sunset] createTask - index: 0, static: true, opt: {"name":"schedule1","topic":"topic1","payloadType":"default","payload":"","expressionType":"solar","expression":"0 * * * * * *","location":"40.5000244367571, 0.49804377587086346","offset":"0","solarType":"selected","solarEvents":"sunriseEnd","type":"date"}
4 Mar 10:52:52 - [info] [cronplus:6:30] System Time Change Detected!
4 Mar 10:52:52 - [info] [cronplus:6:30] Refreshing running schedules
4 Mar 10:52:52 - [info] [cronplus:8:00 y 18:00] System Time Change Detected!
4 Mar 10:52:52 - [info] [cronplus:8:00 y 18:00] Refreshing running schedules
4 Mar 10:52:52 - [info] [cronplus:6:58] System Time Change Detected!
4 Mar 10:52:52 - [info] [cronplus:6:58] Refreshing running schedules
4 Mar 10:52:52 - [info] [cronplus:De 06 a 19 h] System Time Change Detected!
4 Mar 10:52:52 - [info] [cronplus:De 06 a 19 h] Refreshing running schedules
4 Mar 10:52:52 - [info] [cronplus:De 19 a 05 h] System Time Change Detected!
4 Mar 10:52:52 - [info] [cronplus:De 19 a 05 h] Refreshing running schedules
4 Mar 10:52:52 - [info] [cronplus:Cada hora] System Time Change Detected!
4 Mar 10:52:52 - [info] [cronplus:Cada hora] Refreshing running schedules
4 Mar 10:52:52 - [info] [cronplus:Amanece] System Time Change Detected!
4 Mar 10:52:52 - [info] [cronplus:Amanece] Refreshing running schedules
4 Mar 10:52:52 - [info] [cronplus:Amanece] createTask - index: 0, static: true, opt: {"name":"schedule1","topic":"topic1","payloadType":"default","payload":"","expressionType":"solar","expression":"0 * * * * * *","location":"40.5000244367571, 0.49804377587086346","offset":"0","solarType":"selected","solarEvents":"sunriseEnd","type":"date"}
4 Mar 10:52:52 - [info] [cronplus:al amanecer] System Time Change Detected!
4 Mar 10:52:52 - [info] [cronplus:al amanecer] Refreshing running schedules
4 Mar 10:52:52 - [info] [cronplus:al amanecer] createTask - index: 0, static: true, opt: {"name":"schedule2","topic":"topic2","payloadType":"default","payload":"","expressionType":"solar","expression":"0 * * * * * *","location":"40.4998918538739, 0.4980711056850851","offset":"0","solarType":"selected","solarEvents":"sunrise","type":"date"}
4 Mar 10:52:52 - [info] [cronplus:Sol en lo alto] System Time Change Detected!
4 Mar 10:52:52 - [info] [cronplus:Sol en lo alto] Refreshing running schedules
4 Mar 10:52:52 - [info] [cronplus:Sol en lo alto] createTask - index: 0, static: true, opt: {"name":"schedule1","topic":"topic1","payloadType":"default","payload":"","expressionType":"solar","expression":"0 * * * * * *","location":"51.025, -1.4","offset":"0","solarType":"selected","solarEvents":"solarNoon","type":"date"}
4 Mar 10:52:52 - [info] [cronplus:2 h antes de sol en lo alto] System Time Change Detected!
4 Mar 10:52:52 - [info] [cronplus:2 h antes de sol en lo alto] Refreshing running schedules
4 Mar 10:52:52 - [info] [cronplus:2 h antes de sol en lo alto] createTask - index: 0, static: true, opt: {"name":"schedule1","topic":"topic1","payloadType":"default","payload":"","expressionType":"solar","expression":"0 * * * * * *","location":"51.025, -1.4","offset":"-120","solarType":"selected","solarEvents":"solarNoon","type":"date"}
4 Mar 10:52:52 - [info] [cronplus:10:00 y 14:00 L-V] System Time Change Detected!
4 Mar 10:52:52 - [info] [cronplus:10:00 y 14:00 L-V] Refreshing running schedules
4 Mar 10:52:52 - [info] [cronplus:1 de enero] System Time Change Detected!
4 Mar 10:52:52 - [info] [cronplus:1 de enero] Refreshing running schedules
4 Mar 10:52:52 - [info] [cronplus:1 de mayo] System Time Change Detected!
4 Mar 10:52:52 - [info] [cronplus:1 de mayo] Refreshing running schedules
4 Mar 10:52:52 - [info] [cronplus:15 de agosto] System Time Change Detected!
4 Mar 10:52:52 - [info] [cronplus:15 de agosto] Refreshing running schedules
4 Mar 10:52:52 - [info] [cronplus:1 de noviembre] System Time Change Detected!
4 Mar 10:52:52 - [info] [cronplus:1 de noviembre] Refreshing running schedules
4 Mar 10:52:52 - [info] [cronplus:6 de diciembre] System Time Change Detected!
4 Mar 10:52:52 - [info] [cronplus:6 de diciembre] Refreshing running schedules
4 Mar 10:52:52 - [info] [cronplus:8 de diciembre] System Time Change Detected!
4 Mar 10:52:52 - [info] [cronplus:8 de diciembre] Refreshing running schedules
4 Mar 10:52:52 - [info] [cronplus:25 de diciembre] System Time Change Detected!
4 Mar 10:52:52 - [info] [cronplus:25 de diciembre] Refreshing running schedules
4 Mar 10:52:52 - [info] [cronplus:f4e011d82552b281] System Time Change Detected!
4 Mar 10:52:52 - [info] [cronplus:f4e011d82552b281] Refreshing running schedules
4 Mar 10:52:52 - [info] [cronplus:f4e011d82552b281] createTask - index: 0, static: true, opt: {"name":"schedule1","topic":"topic1","payloadType":"default","payload":"","expressionType":"solar","expression":"0 * * * * * *","location":"40.5000244367571, 0.49804377587086346","offset":"0","solarType":"selected","solarEvents":"civilDusk","type":"date"}
4 Mar 10:52:52 - [info] [cronplus:Sunrise -20'] System Time Change Detected!
4 Mar 10:52:52 - [info] [cronplus:Sunrise -20'] Refreshing running schedules
4 Mar 10:52:52 - [info] [cronplus:Sunrise -20'] createTask - index: 0, static: true, opt: {"name":"schedule1","topic":"topic1","payloadType":"default","payload":"","expressionType":"solar","expression":"*/5 7-11 * * *","location":"40.5000244367571 0.49804377587086346","offset":"-20","solarType":"selected","solarEvents":"sunrise","type":"date"}
4 Mar 10:52:52 - [info] [cronplus:a y 20 y 40' de 10 a 20 L-V] System Time Change Detected!
4 Mar 10:52:52 - [info] [cronplus:a y 20 y 40' de 10 a 20 L-V] Refreshing running schedules
4 Mar 10:52:52 - [info] [cronplus:L-V 18:00] System Time Change Detected!
4 Mar 10:52:52 - [info] [cronplus:L-V 18:00] Refreshing running schedules
4 Mar 10:58:15 - [info] [cronplus:/20' - 1.0] System Time Change Detected!
4 Mar 10:58:15 - [info] [cronplus:/20' - 1.0] Refreshing running schedules
4 Mar 10:58:15 - [info] [cronplus:X:30' entre [7-17) L-V] System Time Change Detected!
4 Mar 10:58:15 - [info] [cronplus:X:30' entre [7-17) L-V] Refreshing running schedules
4 Mar 10:58:15 - [info] [cronplus:X:45' entre [7-17) L-V] System Time Change Detected!
4 Mar 10:58:15 - [info] [cronplus:X:45' entre [7-17) L-V] Refreshing running schedules
4 Mar 10:58:15 - [info] [cronplus:c/5' entre [8-17) L-V] System Time Change Detected!
4 Mar 10:58:15 - [info] [cronplus:c/5' entre [8-17) L-V] Refreshing running schedules
4 Mar 10:58:15 - [info] [cronplus:X:55' entre [07-17) L-V] System Time Change Detected!
4 Mar 10:58:15 - [info] [cronplus:X:55' entre [07-17) L-V] Refreshing running schedules
4 Mar 10:58:15 - [info] [cronplus:Viernes a las 18:00] System Time Change Detected!
4 Mar 10:58:15 - [info] [cronplus:Viernes a las 18:00] Refreshing running schedules
4 Mar 10:58:15 - [info] [cronplus:X:50' entre [7-17 L-V] System Time Change Detected!
4 Mar 10:58:15 - [info] [cronplus:X:50' entre [7-17 L-V] Refreshing running schedules
4 Mar 10:58:15 - [info] [cronplus:e655dff5947e57da] System Time Change Detected!
4 Mar 10:58:15 - [info] [cronplus:e655dff5947e57da] Refreshing running schedules
4 Mar 10:58:15 - [info] [cronplus:b100698d70690f9d] System Time Change Detected!
4 Mar 10:58:15 - [info] [cronplus:b100698d70690f9d] Refreshing running schedules
4 Mar 10:58:15 - [info] [cronplus:Sol en lo alto -90'] System Time Change Detected!
4 Mar 10:58:15 - [info] [cronplus:Sol en lo alto -90'] Refreshing running schedules
4 Mar 10:58:15 - [info] [cronplus:Sol en lo alto -90'] createTask - index: 0, static: true, opt: {"name":"schedule1","topic":"topic1","payloadType":"default","payload":"","expressionType":"solar","expression":"0 * * * * * *","location":"51.025, -1.4","offset":"-90","solarType":"selected","solarEvents":"solarNoon","type":"date"}
4 Mar 10:58:15 - [info] [cronplus:Sol en lo alto -25'] System Time Change Detected!
4 Mar 10:58:15 - [info] [cronplus:Sol en lo alto -25'] Refreshing running schedules
4 Mar 10:58:15 - [info] [cronplus:Sol en lo alto -25'] createTask - index: 0, static: true, opt: {"name":"schedule1","topic":"topic1","payloadType":"default","payload":"","expressionType":"solar","expression":"0 * * * * * *","location":"51.025, -1.4","offset":"-25","solarType":"selected","solarEvents":"solarNoon","type":"date"}
4 Mar 10:58:15 - [info] [cronplus:/5' de 7 a 12 am] System Time Change Detected!
4 Mar 10:58:15 - [info] [cronplus:/5' de 7 a 12 am] Refreshing running schedules
4 Mar 10:58:15 - [info] [cronplus:Atardecer empieza -30] System Time Change Detected!
4 Mar 10:58:15 - [info] [cronplus:Atardecer empieza -30] Refreshing running schedules
4 Mar 10:58:15 - [info] [cronplus:Atardecer empieza -30] createTask - index: 0, static: true, opt: {"name":"schedule1","topic":"topic1","payloadType":"default","payload":"","expressionType":"solar","expression":"0 * * * * * *","location":"40.5000244367571 0.49804377587086346","offset":"-30","solarType":"selected","solarEvents":"eveningGoldenHourStart","type":"date"}
4 Mar 10:58:15 - [info] [cronplus:Sunset] System Time Change Detected!
4 Mar 10:58:15 - [info] [cronplus:Sunset] Refreshing running schedules
4 Mar 10:58:15 - [info] [cronplus:Sunset] createTask - index: 0, static: true, opt: {"name":"schedule1","topic":"topic1","payloadType":"default","payload":"","expressionType":"solar","expression":"0 * * * * * *","location":"40.5000244367571, 0.49804377587086346","offset":"0","solarType":"selected","solarEvents":"sunset","type":"date"}
4 Mar 10:58:15 - [info] [cronplus:Sunset] createTask - index: 0, static: true, opt: {"name":"schedule1","topic":"topic1","payloadType":"default","payload":"","expressionType":"solar","expression":"0 * * * * * *","location":"40.5000244367571, 0.49804377587086346","offset":"0","solarType":"selected","solarEvents":"sunriseEnd","type":"date"}
4 Mar 10:58:15 - [info] [cronplus:6:30] System Time Change Detected!
4 Mar 10:58:15 - [info] [cronplus:6:30] Refreshing running schedules
4 Mar 10:58:15 - [info] [cronplus:8:00 y 18:00] System Time Change Detected!
4 Mar 10:58:15 - [info] [cronplus:8:00 y 18:00] Refreshing running schedules
4 Mar 10:58:15 - [info] [cronplus:6:58] System Time Change Detected!
4 Mar 10:58:15 - [info] [cronplus:6:58] Refreshing running schedules
4 Mar 10:58:15 - [info] [cronplus:De 06 a 19 h] System Time Change Detected!
4 Mar 10:58:15 - [info] [cronplus:De 06 a 19 h] Refreshing running schedules
4 Mar 10:58:15 - [info] [cronplus:De 19 a 05 h] System Time Change Detected!
4 Mar 10:58:15 - [info] [cronplus:De 19 a 05 h] Refreshing running schedules
4 Mar 10:58:15 - [info] [cronplus:Cada hora] System Time Change Detected!
4 Mar 10:58:15 - [info] [cronplus:Cada hora] Refreshing running schedules
4 Mar 10:58:15 - [info] [cronplus:Amanece] System Time Change Detected!
4 Mar 10:58:15 - [info] [cronplus:Amanece] Refreshing running schedules
4 Mar 10:58:15 - [info] [cronplus:Amanece] createTask - index: 0, static: true, opt: {"name":"schedule1","topic":"topic1","payloadType":"default","payload":"","expressionType":"solar","expression":"0 * * * * * *","location":"40.5000244367571, 0.49804377587086346","offset":"0","solarType":"selected","solarEvents":"sunriseEnd","type":"date"}
4 Mar 10:58:15 - [info] [cronplus:al amanecer] System Time Change Detected!
4 Mar 10:58:15 - [info] [cronplus:al amanecer] Refreshing running schedules
4 Mar 10:58:15 - [info] [cronplus:al amanecer] createTask - index: 0, static: true, opt: {"name":"schedule2","topic":"topic2","payloadType":"default","payload":"","expressionType":"solar","expression":"0 * * * * * *","location":"40.4998918538739, 0.4980711056850851","offset":"0","solarType":"selected","solarEvents":"sunrise","type":"date"}
4 Mar 10:58:15 - [info] [cronplus:Sol en lo alto] System Time Change Detected!
4 Mar 10:58:15 - [info] [cronplus:Sol en lo alto] Refreshing running schedules
4 Mar 10:58:15 - [info] [cronplus:Sol en lo alto] createTask - index: 0, static: true, opt: {"name":"schedule1","topic":"topic1","payloadType":"default","payload":"","expressionType":"solar","expression":"0 * * * * * *","location":"51.025, -1.4","offset":"0","solarType":"selected","solarEvents":"solarNoon","type":"date"}
4 Mar 10:58:15 - [info] [cronplus:2 h antes de sol en lo alto] System Time Change Detected!
4 Mar 10:58:15 - [info] [cronplus:2 h antes de sol en lo alto] Refreshing running schedules
4 Mar 10:58:15 - [info] [cronplus:2 h antes de sol en lo alto] createTask - index: 0, static: true, opt: {"name":"schedule1","topic":"topic1","payloadType":"default","payload":"","expressionType":"solar","expression":"0 * * * * * *","location":"51.025, -1.4","offset":"-120","solarType":"selected","solarEvents":"solarNoon","type":"date"}
4 Mar 10:58:15 - [info] [cronplus:10:00 y 14:00 L-V] System Time Change Detected!
4 Mar 10:58:15 - [info] [cronplus:10:00 y 14:00 L-V] Refreshing running schedules
4 Mar 10:58:15 - [info] [cronplus:1 de enero] System Time Change Detected!
4 Mar 10:58:15 - [info] [cronplus:1 de enero] Refreshing running schedules
4 Mar 10:58:15 - [info] [cronplus:1 de mayo] System Time Change Detected!
4 Mar 10:58:15 - [info] [cronplus:1 de mayo] Refreshing running schedules
4 Mar 10:58:15 - [info] [cronplus:15 de agosto] System Time Change Detected!
4 Mar 10:58:15 - [info] [cronplus:15 de agosto] Refreshing running schedules
4 Mar 10:58:15 - [info] [cronplus:1 de noviembre] System Time Change Detected!
4 Mar 10:58:15 - [info] [cronplus:1 de noviembre] Refreshing running schedules
4 Mar 10:58:15 - [info] [cronplus:6 de diciembre] System Time Change Detected!
4 Mar 10:58:15 - [info] [cronplus:6 de diciembre] Refreshing running schedules
4 Mar 10:58:15 - [info] [cronplus:8 de diciembre] System Time Change Detected!
4 Mar 10:58:15 - [info] [cronplus:8 de diciembre] Refreshing running schedules
4 Mar 10:58:15 - [info] [cronplus:25 de diciembre] System Time Change Detected!
4 Mar 10:58:15 - [info] [cronplus:25 de diciembre] Refreshing running schedules
4 Mar 10:58:15 - [info] [cronplus:f4e011d82552b281] System Time Change Detected!
4 Mar 10:58:15 - [info] [cronplus:f4e011d82552b281] Refreshing running schedules
4 Mar 10:58:15 - [info] [cronplus:f4e011d82552b281] createTask - index: 0, static: true, opt: {"name":"schedule1","topic":"topic1","payloadType":"default","payload":"","expressionType":"solar","expression":"0 * * * * * *","location":"40.5000244367571, 0.49804377587086346","offset":"0","solarType":"selected","solarEvents":"civilDusk","type":"date"}
4 Mar 10:58:15 - [info] [cronplus:Sunrise -20'] System Time Change Detected!
4 Mar 10:58:15 - [info] [cronplus:Sunrise -20'] Refreshing running schedules
4 Mar 10:58:15 - [info] [cronplus:Sunrise -20'] createTask - index: 0, static: true, opt: {"name":"schedule1","topic":"topic1","payloadType":"default","payload":"","expressionType":"solar","expression":"*/5 7-11 * * *","location":"40.5000244367571 0.49804377587086346","offset":"-20","solarType":"selected","solarEvents":"sunrise","type":"date"}
4 Mar 10:58:15 - [info] [cronplus:a y 20 y 40' de 10 a 20 L-V] System Time Change Detected!
4 Mar 10:58:15 - [info] [cronplus:a y 20 y 40' de 10 a 20 L-V] Refreshing running schedules
4 Mar 10:58:15 - [info] [cronplus:L-V 18:00] System Time Change Detected!
4 Mar 10:58:16 - [info] [cronplus:L-V 18:00] Refreshing running schedules
4 Mar 10:58:16 - [red] Uncaught Exception:
4 Mar 10:58:16 - [error] UnhandledPromiseRejection: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason "3".
at throwUnhandledRejectionsMode (node:internal/process/promises:392:7)
at processPromiseRejections (node:internal/process/promises:475:17)
at processTicksAndRejections (node:internal/process/task_queues:106:32)
[10:58:16] INFO: Service Node-RED exited with code 1 (by signal 0)
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service nginx: stopping
[10:58:16] INFO: Service NGINX exited with code 0 (by signal 0)
s6-rc: info: service nginx successfully stopped
s6-rc: info: service init-nginx: stopping
s6-rc: info: service nodered: stopping
s6-rc: info: service nodered successfully stopped
s6-rc: info: service init-nodered: stopping
s6-rc: info: service init-nginx successfully stopped
s6-rc: info: service init-nodered successfully stopped
s6-rc: info: service init-customizations: stopping
s6-rc: info: service init-customizations successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service base-addon-log-level: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service base-addon-log-level successfully stopped
s6-rc: info: service base-addon-banner: stopping
s6-rc: info: service base-addon-banner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service base-addon-banner: starting
Add-on: Node-RED
Flow-based programming for the Internet of Things
Add-on version: 19.0.2
You are running the latest version of this add-on.
System: Home Assistant OS 14.2 (amd64 / generic-x86-64)
Home Assistant Core: 2025.2.5
Home Assistant Supervisor: 2025.03.0
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
