Tabs bar blueish?
Using dark theme.
Why is everything else black but the top “Tabs bar” blueish?
Can that be changed?
//Ase
No big deal, but am I the only one notising this odd coloring still present today?
Here I added some extra brightness so it is more obvious:
Look into Themes. You can set them in your profile
You can design your own theme:
There are also many themes online (Google “Home Assistant Theme”)and within HACS. Be aware that stuff in HACS is not tested/reviewed by the Home Assistant Team.
Any ideas of what to add into frontend.yaml to change just this “Tabs bar” line from blueish to black/grey as the rest?
