Tado - Action: Update Gas Usage - Working?
Has anyone got this working ?
Specifically the updating of Gas Usage to Tado at
Tado Integration
Everything else is working fine, except for the constant re-auths involved.
Whenever I try to update the gas reading I get an error “Error: meter readings not allowed for home”
So is this part of the Tado auth issue?
Solved it!!!
You need to change in the Tado App Energy IQ/Data Source/Type and Unit to Meter readings!!
Then it allows the Home Assistant update to work!
