Tado-based heating energy tracker with daily estimation
Hey everyone,
I built a small system to track and estimate heating energy consumption in Home Assistant using Tado thermostat valve positions — useful if you only receive actual consumption data once a month from your landlord or utility provider.
The problem
My landlord provides monthly kWh readings for central heating. Previously I just divided the total equally across all days. That’s obviously not very accurate — a cold week with lots of heating looks the same as a warm week.
The solution
Two Python scripts that write directly to the MariaDB statistics tables:
1. Monthly import — when you receive your actual kWh reading, it distributes the total across all days weighted by Tado valve activity. Days with warm outdoor temperatures and zero Tado activity (= central heating off in summer) get weight 0 automatically.
2. Daily estimation — runs every night at 03:00 and estimates the current month’s consumption in real time. It learns a calibration factor (kWh per Tado unit) from your historical actual readings. The more months of real data you have, the more accurate it gets. With just 1 month it already works reasonably well.
How the calibration works
For each month with actual data:
factor = actual_kWh / sum_of_daily_tado_averages
Newer months are weighted exponentially higher, so the estimate adapts over time.
Requirements
- Home Assistant with MariaDB add-on
- Tado integration (heating percentage sensors)
- Outdoor temperature sensor (for summer detection)
- pymysql Python package
GitHub
Full installation instructions, configuration, and both scripts:
GitHub - groovyM/HA-Tado-Heating-Tracker: Tado-based heating energy tracker and estimator for Home Assistant · GitHub
Happy to answer questions or take suggestions for improvements!
