Hi
on a RP4 this all seems to work OK.
I am installing HA on a Win 10 pc and using WM Virtualbox (also tried VMWare). I have seen older posts with people with problems like this but nothing seems to work.
When I 1st try to set up Tado on a clean system it works and detects all the kit in the house and I can change the temp in the rooms using HA.
BUT, as soon as I restart anything tado fails to start up, if I remove the intragration it fails to set up again.
Any ideas anyone
Logger: homeassistant.config_entries
Source: components/tado/__init__.py:195
First occurred: 11:17:29 (1 occurrences)
Last logged: 11:17:29
Error setting up entry Our Home for tado
File "/usr/local/lib/python3.10/site-packages/urllib3/connectionpool.py", line 449, in _make_request
six.raise_from(e, None)
File "<string>", line 3, in raise_from
File "/usr/local/lib/python3.10/site-packages/urllib3/connectionpool.py", line 444, in _make_request
httplib_response = conn.getresponse()
File "/usr/local/lib/python3.10/http/client.py", line 1374, in getresponse
response.begin()
File "/usr/local/lib/python3.10/http/client.py", line 318, in begin
version, status, reason = self._read_status()
File "/usr/local/lib/python3.10/http/client.py", line 279, in _read_status
line = str(self.fp.readline(_MAXLINE + 1), "iso-8859-1")
File "/usr/local/lib/python3.10/socket.py", line 705, in readinto
return self._sock.recv_into(b)
File "/usr/local/lib/python3.10/ssl.py", line 1274, in recv_into
return self.read(nbytes, buffer)
File "/usr/local/lib/python3.10/ssl.py", line 1130, in read
return self._sslobj.read(len, buffer)
TimeoutError: The read operation timed out
File "/usr/local/lib/python3.10/site-packages/requests/adapters.py", line 489, in send
resp = conn.urlopen(
File "/usr/local/lib/python3.10/site-packages/urllib3/connectionpool.py", line 787, in urlopen
retries = retries.increment(
File "/usr/local/lib/python3.10/site-packages/urllib3/util/retry.py", line 550, in increment
raise six.reraise(type(error), error, _stacktrace)
File "/usr/local/lib/python3.10/site-packages/urllib3/packages/six.py", line 770, in reraise
raise value
File "/usr/local/lib/python3.10/site-packages/urllib3/connectionpool.py", line 703, in urlopen
httplib_response = self._make_request(
File "/usr/local/lib/python3.10/site-packages/urllib3/connectionpool.py", line 451, in _make_request
self._raise_timeout(err=e, url=url, timeout_value=read_timeout)
File "/usr/local/lib/python3.10/site-packages/urllib3/connectionpool.py", line 340, in _raise_timeout
raise ReadTimeoutError(
urllib3.exceptions.ReadTimeoutError: HTTPSConnectionPool(host='my.tado.com', port=443): Read timed out. (read timeout=10)
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 382, in async_setup
result = await component.async_setup_entry(hass, self)
File "/usr/src/homeassistant/homeassistant/components/tado/__init__.py", line 78, in async_setup_entry
await hass.async_add_executor_job(tadoconnector.update)
File "/usr/local/lib/python3.10/concurrent/futures/thread.py", line 58, in run
File "/usr/src/homeassistant/homeassistant/util/__init__.py", line 190, in wrapper
result = method(*args, **kwargs)
File "/usr/src/homeassistant/homeassistant/components/tado/__init__.py", line 176, in update
self.update_devices()
File "/usr/src/homeassistant/homeassistant/components/tado/__init__.py", line 195, in update_devices
device[TEMP_OFFSET] = self.tado.getDeviceInfo(
File "/usr/local/lib/python3.10/site-packages/PyTado/interface.py", line 425, in getDeviceInfo
data = self._apiCall(cmd=cmd, domain=self.DEVICE_DOMAIN, device_id=device_id)
File "/usr/local/lib/python3.10/site-packages/PyTado/interface.py", line 81, in _apiCall
response = self._http_session.request(method, url, timeout=self.timeout,
File "/usr/local/lib/python3.10/site-packages/requests/sessions.py", line 587, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.10/site-packages/requests/sessions.py", line 701, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.10/site-packages/requests/adapters.py", line 578, in send
raise ReadTimeout(e, request=request)
requests.exceptions.ReadTimeout: HTTPSConnectionPool(host='my.tado.com', port=443): Read timed out. (read timeout=10)
