Tado geolocation solution?
Hi Guys,
Last year i installed Tado in my entire home, i got “auto assist” for free for 1 year.
This is now ended and the only option i miss from it is the automatic chaingen to away/home.
I found an integration called “tado assist”, this worked, but always runs into an error.
I presume this is because of the api call limit?
I found “tado hijack”, but it seems this doesn’t do home/away mode?
I created an automation, but this also not seems to work?
I also added tado trough homekit, because i read that this works local instead of the normal integration.
Is there a way to use the home/away function from tado? or do i really have to take the subscription?
