Tado integration in a "The authentication process timed out. Please try again." loop
Hi, I noticed today that my Tado integration stopped working. When reloaded it stated to re-authenticate with Tado. Tried it, but when it succesfully authenticated it HA gives me the message “The authentication process timed out. Please try again.”. When try to dismiss the message by pressing submit, the message keeps on coming back.
I know in the past there were some issues with Tado integration, but wondering is this a new issue?
UPDATE:
Here is some info about my HA:
version: 2026.1.1
Install: HAOS
OS: 16.3
Frontend: 20260107.1
  File "/usr/local/lib/python3.13/site-packages/aiohttp/web_protocol.py", line 510, in _handle_request
    resp = await request_handler(request)
  File "/usr/local/lib/python3.13/site-packages/aiohttp/web_app.py", line 569, in _handle
    return await handler(request)
  File "/usr/local/lib/python3.13/site-packages/aiohttp/web_middlewares.py", line 117, in impl
  File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 92, in security_filter_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 81, in forwarded_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 26, in request_context_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 86, in ban_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 242, in auth_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/headers.py", line 41, in headers_middleware
    response = await handler(request)
  File "/usr/src/homeassistant/homeassistant/helpers/http.py", line 73, in handle
    result = await handler(request, **request.match_info)
  File "/usr/src/homeassistant/homeassistant/components/http/decorators.py", line 83, in with_admin
    return await func(self, request, *args, **kwargs)
  File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 234, in post
    return await super().post(request, flow_id)
  File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 74, in wrapper
    return await method(view, request, data, *args, **kwargs)
  File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 121, in post
    result = await self._flow_mgr.async_configure(flow_id, data)
  File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 346, in async_configure
    result = await self._async_configure(flow_id, user_input)
  File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 393, in _async_configure
    result = await self._async_handle_step(
        flow, cur_step["step_id"], user_input
  File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 493, in _async_handle_step
    result: _FlowResultT = await getattr(flow, method)(user_input)
  File "/usr/src/homeassistant/homeassistant/components/tado/config_flow.py", line 158, in async_step_timeout
    return await self.async_step_user()
  File "/usr/src/homeassistant/homeassistant/components/tado/config_flow.py", line 111, in async_step_user
    "url": tado_device_url,
UnboundLocalError: cannot access local variable 'tado_device_url' where it is not associated with a value
same here
Same here, I’m having the same issue, being unable to get the integration to work.
Same issue here, I tried the authentication several times but nothing.
I’m using:
Home Assistant OS
Core 2026.1.1
Supervisor 2026.01.1
Operating System 16.3
Frontend 20260107.1
Here are the logs, maybe they can help :slight_smile:
2026-01-16 10:49:36.390 WARNING (MainThread) [homeassistant.config_entries] Config entry 'Frusty_Home' for tado integration could not authenticate: Device login flow status is PENDING. Starting re-authentication.
2026-01-16 10:49:51.597 ERROR (MainThread) [homeassistant.components.tado.config_flow] Error while waiting for device activation
  File "/usr/src/homeassistant/homeassistant/components/tado/config_flow.py", line 82, in _wait_for_login
    await self.hass.async_add_executor_job(self.tado.device_activation)
  File "/usr/local/lib/python3.13/concurrent/futures/thread.py", line 59, in run
  File "/usr/local/lib/python3.13/site-packages/PyTado/interface/interface.py", line 107, in device_activation
    self._http.device_activation()
  File "/usr/local/lib/python3.13/site-packages/PyTado/http.py", line 587, in device_activation
    self._device_ready()
  File "/usr/local/lib/python3.13/site-packages/PyTado/http.py", line 591, in _device_ready
    self._id = self._get_id()
  File "/usr/local/lib/python3.13/site-packages/PyTado/http.py", line 602, in _get_id
    homes_ = self.request(request)["homes"]
KeyError: 'homes'
2026-01-16 10:49:59.275 ERROR (MainThread) [aiohttp.server] Error handling request from 192.168.0.1
  File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 87, in forwarded_middleware
2026-01-16 10:50:04.294 ERROR (MainThread) [aiohttp.server] Error handling request from 192.168.0.1
2026-01-16 10:50:04.341 ERROR (MainThread) [homeassistant.components.tado.config_flow] Error while waiting for device activation
  File "/usr/local/lib/python3.13/site-packages/PyTado/http.py", line 584, in device_activation
    if self._check_device_activation():
  File "/usr/local/lib/python3.13/site-packages/PyTado/http.py", line 575, in _check_device_activation
    raise TadoException(f"Login failed. Reason: {token_response.reason}")
PyTado.exceptions.TadoException: Login failed. Reason: Bad Request
2026-01-16 10:50:04.344 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved (task: None)
  File "/usr/src/homeassistant/homeassistant/components/tado/config_flow.py", line 85, in _wait_for_login
    raise CannotConnect from ex
homeassistant.components.tado.config_flow.CannotConnect
2026-01-16 10:50:08.008 ERROR (MainThread) [aiohttp.server] Error handling request from 192.168.0.1
2026-01-16 10:50:09.359 ERROR (MainThread) [homeassistant.components.tado.config_flow] Error while waiting for device activation
2026-01-16 10:50:09.362 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved (task: None)
2026-01-16 10:50:13.073 ERROR (MainThread) [homeassistant.components.tado.config_flow] Error while waiting for device activation
Exactly the same for me this morning.
Same here.
Same here since 07:08 GMT +1.
Glad to see I’m not the only one. It was working fine before I had reboot HA after upgrading some HACS integration. It’s weird to see that it confirms fine at first but then back in HA you get the time out.
Same here, after a reboot started getting:
Unknown error occurred
I’m happy because I’m not alone :smiley:
I was having the same issue this morning. Tried to remove the integration, restart and everything but the problem was still there.
I tried again 30 minutes ago and now it’s back up and working for me. I don’t have any Tado subscription, just using the base account
Yes, I’ve just been able to authenticate, and the integration is now working again!
The integration is back now
Just tried re-authenticate, and works again for me.
confirmed it works after restarting HA
Is it down again? Had the same issue after updating HA and restarting
Is that for the Tado yoyo?
Yes, seems to be down, I‘m experiencing the same situation like yesterday morning.
Yes, same again for me. Very annoying.
I also can confirm experiencing the same issue. With so many having this and Tado past attempts to stop their API being used my first thoughts is that this maybe something on the side of Tado? And we need to hope its just a bug and not a ‘feature’?
If its the latter to drive people to pay it means I will start looking for new hardware to replace Tado. But not going to jump to conclusions. But mindfull with all the bad decisions they have been making regarding their API.
