Tado radiator, unable to set temp in HA
I am suddenly unable to set temperature for my Tado radiator valve through HA. It seems to have occurred about the time when I updated from 2021.1.5 to 2021.2.2. I can’t find anyone else having similar issues(?) First noticed that my automations didn’t work, but doesn’t seem automation related as it’s not working manually changing climate entity parameters either.
When temperature is set manually on the valve it’s updated in the climate entity in HA and in Tado app. When temperature is set in app it’s updated in the climate entity in HA and on the device. When I attempt to change temperature or mode through the climate entity in HA I can visibly change the parameters, but it doesn’t take effect and is reverted automatically after 2-3sec. No change on the device itself. I can’t see any error in logs.
Remove/add integration didn’t help.
Ideas appreciated.
Breaking change maybe?
I’ve noticed the listed breaking change and change of my sensors according to the breaking change. As it’s a change in the integration I assume it likely related to my issues somehow, but I can’t see why it should affect the climate entity this way. (My configuration was UI already.)
Edit: It seems I can currently only retrieve data through the integration. I can no longer set any parameters regardless of how I attempt to achieve it.
Solution is: go to integrations, then settings, then options (3 dots), uncheck fall back !
Then it should work again!
I have the same problem. Unchecking Enable fallback mode. in integration settings solved the issue. But why the behaviour suddenly changed?
