Hello Guys,
today i noticed that my thermostat is giving an error when changing any value:
Translated from dutch:
Cannot call service climate/set_temperature. ‘acces token’
Obviously its missing a token, probably my token expired. I cannot remember if i had to make a token when installing tado. But the question is how do i make a new token and install it in home assistant.
Or is there any other way to solve this.
Home assistant does see my thermostat, and also does see the internet bridge…
I can change the temperature (from a distance) on my home bridge, but this does not include hvac modes. So i will need to fix my thermostat entity.
The thermostat does display the current temperature, and mode. the only issue is that i cannot operate it in any way. through the thermostat.
Before deleting it completely and re-adding it. i was hoping for a better solutionm
Hope anyone has already experienced this.
