Tado X and custom thermostats
Hi all.
I’m planning the use of Tado X with Tado valves, on each radiator I have.
I would like (and it’s a strict requirements) to be able to set different temperatures for each room. With Tado X wireless thermostat (or directly with the valve) this is possible, but I would like to use a different thermostat in each room, like the Tuya one, much more better looking.
Do you know if is possible to use different thermostats to read/set the Tado temperatura ? The tado thermostat is huge…
I would also be interested if that worked. Have you been successful in implementing a different thermostat?
