Tado X Offset in Home Assistant
Introduction
Tado X radiator thermostats measure the temperature directly at the radiator, often leading to inaccurate readings. With this solution, you can automatically adjust the temperature offset by using external room thermostats as a reference.
This guide shows you how to set the offset via Home Assistant by regularly generating a new access token and calculating the temperature difference between the room thermostat and the radiator thermostat.
Requirements
  • Home Assistant (HA)
  • Tado X radiator thermostats
  • A separate room thermostat for more accurate measurements
  • Developer tools in Firefox or Chrome to retrieve the refresh token
Step 1: Retrieve the Refresh Token
  1. Open the developer tab (before logging in!):
  • Open app.tado.com, but do not log in yet!
  • Open the developer tools with F12 and go to the Network tab → XHR.
  • Now log in.
  • Click on the first POST result. There, you will find the refresh token and client ID in the response, which you will need later in the configuration.yaml.
  1. Create a JSON file in Home Assistant Open the File Editor or the Studio Code Server and create the following file /config/tado_rooms_devices.json and /config/tado_response.json with the following content:
{"refresh_token":"YOUR_REFRESH_TOKEN"}
Step 2: Add Shell Commands to configuration.yaml
Open your configuration.yaml and add the following Shell Commands: ADD YOUR CLIENT ID
shell_command:
  get_tado_token: >-
    curl -s -X POST "https://login.tado.com/oauth2/token"
    -d "client_id=>>>>>>>>>>>>>>>>CLIENT_ID_HERE<<<<<<<<<<<<<<<<<<"
    -d "grant_type=refresh_token"
    -d "refresh_token=$(jq -r '.refresh_token' /config/tado_response.json)"
  set_temperature_offset: >-
    curl "https://hops.tado.com/homes/1763547/roomsAndDevices/devices/{{ device }}?ngsw-bypass=true"
    -X PATCH
    -H "User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:136.0) Gecko/20100101 Firefox/136.0"
    -H "Accept: application/json, text/plain, */*"
    -H "Accept-Language: it-IT,it;q=0.8,en-US;q=0.5,en;q=0.3"
    -H "Accept-Encoding: gzip, deflate, br, zstd"
    -H "Content-Type: application/json"
    -H "Referer: https://app.tado.com/"
    -H "X-Amzn-Trace-Id: tado=webapp-2025.3.6.10.51-release/v3676"
    -H "Origin: https://app.tado.com"
    -H "Sec-Fetch-Dest: empty"
    -H "Sec-Fetch-Mode: cors"
    -H "Sec-Fetch-Site: same-site"
    -H "Authorization: Bearer {{ access_token }}"
    -H "Connection: keep-alive"
    -H "Priority: u=0"
    -H "TE: trailers"
    --data-raw '{"temperatureOffset":{{ offset }}}'
  get_tado_access_token: "jq -r '.access_token' /config/tado_response.json"
  get_tado_rooms_devices_json: "jq -r '.' /config/tado_rooms_devices.json"
  get_tado_temperature_as_measured: >-
    jq -r '.rooms[].devices[] | select(.serialNumber=="{{ device }}") | .temperatureAsMeasured' /config/tado_rooms_devices.json
  get_tado_rooms_devices: >-
    curl -s "https://hops.tado.com/homes/1763547/roomsAndDevices?ngsw-bypass=true"
    -H "X-Amzn-Trace-Id: tado=webapp-2025.3.7.9.55-release/v3677"
    -H "Authorization: Bearer $(jq -r '.access_token' /config/tado_response.json)"
    -H "TE: trailers"
Save and restart Home Assistant!
Step 3: Automation to Refresh the Access Token
Since the Access Token expires every 10 minutes, a new one must be generated regularly. Create a new automation with the following YAML code:
alias: Tado Load New Access Token Every 9 Minutes
description: ""
  - platform: time_pattern
    minutes: "/9"
  - service: shell_command.get_tado_token
mode: single
Step 4: Automation to Calculate the Offset
Each time the temperature from the room thermostat or the Tado radiator valve changes, the offset is calculated and set:
alias: Offset berechnen
description: ""
triggers:
  - trigger: state
    entity_id:
      - sensor.ROOMTermostat
  - trigger: state
    entity_id:
      - sensor.Tado_Radiator_Termostat
conditions: []
actions:
  - action: shell_command.get_tado_rooms_devices
    metadata: {}
    data: {}
  - action: shell_command.get_tado_temperature_as_measured
    metadata: {}
      device: VAxxxxxxxxxx
    response_variable: temperature_as_measured
  - action: shell_command.get_tado_access_token
    data: {}
    response_variable: bearer
  - action: shell_command.set_temperature_offset
      offset: >-
        {{ ((states('sensor.ROOMTermostat') | float(0)) -
        (temperature_as_measured.stdout | float(0))) | round(1) }}
      access_token: "{{bearer.stdout}}"
  - delay:
      hours: 0
      minutes: 0
      seconds: 30
      milliseconds: 0
    enabled: true
mode: single
Explanations:
  • INSERT_YOUR_DEVICE_SERIAL_NUMBER_HERE: Replace VAxxxxxxxxxx with the serial number of your Tado radiator thermostat.
  • sensor.ROOMTermostat = Room thermostat for accurate measurement.
  • sensor.Tado_Radiator_Termostat = Tado radiator thermostat.
Step 5: Testing & Activation
  1. Generate the Access Token: Go to Developer Tools → Actions and start shell_command.get_tado_token.
  2. Check the file: Open /config/tado_response.json and ensure that the access_token is stored.
  3. Start the automation:
  • Activate the 9-minute token renewal.
  • Activate the offset calculation automation.
  • Check the temperature values and offset values in Home Assistant.
  • Ensure that the offset is applied in the Tado app.
Is this needed when integrated via Matter ?
over matter you can only set the Heat mode and the setpoint. nothing else.
in the `tado_rooms_devices.json you have also other informations like the percent of heating of eatch valve ect.
Good approach, thanks for this!
One suggestion for the documentation @Zanooon97 : we need to use our own home ID’s in the API calls. Otherwise the rooms json is staying empty :slight_smile:
right! thanks for the comment.
To se the heatingpower as a sensor in HA you need to add the following code in the config file:
  • remember to add Your HomeID and Device Names (in the documantation before you need to add also Your HomeID in the shell command)
  • create the file: tado_rooms.json
  • create the automation to update the tado_rooms.json eatch minute
shell_command:
 get_tado_rooms: >-
    curl -s "https://hops.tado.com/homes/>>>>YOUR HOME ID<<<</rooms?ngsw-bypass=true"
    -H "X-Amzn-Trace-Id: tado=webapp-2025.3.10.10.52-release/v3678"
    -H "TE: trailers"
    > /config/tado_rooms.json
command_line:
  - sensor:
      name: "Tado Device 1 Heatingpower"
      command: 'jq -r ''.[] | select(.name==">>>>YOUR DEVICE NAME<<<<") | .heatingPower.percentage // 0'' /config/tado_rooms.json'
      unit_of_measurement: "%"
      scan_interval: 10
  - sensor:
      name: "Tado Device 2 Heatingpower"
      scan_interval: 10
automation:
alias: Tado Rooms alle 60 sek. neu laden fĂźr HeatingPower
description: ""
triggers:
  - trigger: time_pattern
    seconds: /59
conditions: []
actions:
    metadata: {}
    data: {}
mode: single
I followed your guide and need to manually re-paste my access token manually every week or so (step 1). Any suggestions?
FYI. I switched to the auth-flow described here: How do I authenticate to access the REST API? | Help Center for tado° V3+ and earlier devices
And have not had issues since.
Nice job, i will try this.
Thank you this was a issue also for me
Hi, do you have some examples in Home Assistant to get this auth-flow working? Thanks.
i will make a new instruction.
Tado OAuth Device Authentication (Home Assistant)
  1. Install dependency
pip3 install requests
  1. Request Device Code
python3 -c “import requests; r = requests.post(‘https://login.tado.com/oauth2/device_authorize’, params={‘client_id’: ‘1bb50063-6b0c-4d11-bd99-387f4a91cc46’, ‘scope’: ‘offline_access’}); print(r.status_code, r.text)”
Open verification_uri_complete
Log in with your Tado account
Save the device_code
Expected response:
“device_code”: “XXX_code_XXX”,
“expires_in”: 300,
“interval”: 5,
“user_code”: “7BQ5ZQ”,
“verification_uri”: “Login | tado°”,
“verification_uri_complete”: “Login | tado°”
  1. Generate Access & Refresh Tokens
python3 -c “import requests; r = requests.post(‘https://login.tado.com/oauth2/token’, data={‘client_id’: ‘1bb50063-6b0c-4d11-bd99-387f4a91cc46’, ‘device_code’: ‘device______________code’, ‘grant_type’: ‘urn:ietf:params:oauth:grant-type:device_code’}); print(r.status_code); print(r.json())”
Token response:
“access_token”: “myAccessToken”,
“expires_in”: 3599,
“refresh_token”: “myRefreshToken”,
“scope”: “offline_access”,
“token_type”: “Bearer”,
“userId”: “…”
  1. Save tokens
Replace ’ with "
Save to /config/tado_response.json
“expires_in”: 3599,
Done!
Great work on this solution! For anyone looking for a simpler approach, there’s now a custom Tado X integration that includes a built-in service for temperature offset adjustment - no shell commands or manual token handling needed!
:white_check_mark: What It Offers
Temperature Offset Service:
service: tado_x.set_temperature_offset
  device_serial: "your_device_serial"
  offset: 2.5  # -9.9 to +9.9°C
Plus full Tado X functionality:
  • All rooms as climate entities
    • Temperature, humidity, battery, heating power sensors
    • Binary sensors (window open, heating active, etc.)
    • Presets: Schedule, Boost, Home/Away, Auto geofencing
    • Meter reading service for Energy IQ
:inbox_tray: Quick Setup
Via HACS:
  1. Add repository: https://github.com/exabird/ha-tado-x
    1. Install “Tado X”
    1. Restart HA
    1. Add via Settings → Devices & Services
      Authentication: Simple device code flow - get code, authorize on Tado website, done!
:link: More Info
Hey exabird,
I’ve just installed your integration and it works great so far! I just have 1 question. When I’m on schedule mode and manually set the temperature, the termostat goes into boost mode for 30 minutes. I would prefer it goes into manual mode until next scheduled slot like it does on the tado app. Any whas to achieve that through your integration ? Is there a setting I missed?
In any case, thanks for taking the time to develop and share your integration, it really helps!
