Tag 0.63 not found in repository - VM install
I’m trying to install on a VM using these instructions: https://github.com/home-assistant/hassio-build/tree/master/install
I get to the last step involving curl and get the following error: “[INFO] Install supervisor docker” “Tag 0.63 not found in repository docker.io/homeassistant/i386-hassio-supervisor
I installed an earlier version of hass-io using these same instructions and was successful. I’m assuming something didn’t get updated in the install script?
Thank you for any help.
Fix should now work with 0.64
There was a problem by upload of 0.63
It works now. Thank you!
