Tag not reading-Home Assistant Tags
Got my ESP8266 and PN532 connected but I cant get the PN532 to read a tag, any ideas?
ESPHOME shows the ESP8266 is connected. But when I swipe the tag nothing happens.
Is there a process to adding the tags? Or should this just scan and add it?
IMG_0332 (1)
What softwaree are you running on the esp8266, and what does it say in it’s logs?
I used ESPHOME to upload to the ESP8266, ESPHOME is connected to the ESP8266.
Below is the log from ESPHOME,
INFO Reading configuration /config/esphome/kitchen_music.yaml...
INFO Starting log output from kitchen_music.local using esphome API
INFO Connecting to kitchen_music.local:6053 (192.168.0.60)
INFO Successfully connected to kitchen_music.local
[18:10:55][I][app:105]: ESPHome version 1.15.2 compiled on Sep 29 2020, 18:41:56
[18:10:55][C][wifi:443]: WiFi:
[18:10:55][C][wifi:303]:   SSID: [redacted]
[18:10:55][C][wifi:304]:   IP Address: 192.168.0.60
[18:10:55][C][wifi:306]:   BSSID: [redacted]
[18:10:55][C][wifi:307]:   Hostname: 'kitchen_music'
[18:10:55][C][wifi:311]:   Signal strength: -69 dB ▂▄▆█
[18:10:55][C][wifi:315]:   Channel: 4
[18:10:55][C][wifi:316]:   Subnet: 255.255.255.0
[18:10:55][C][wifi:317]:   Gateway: 192.168.0.1
[18:10:55][C][wifi:318]:   DNS1: 192.168.0.1
[18:10:55][C][wifi:319]:   DNS2: (IP unset)
[18:10:55][C][logger:185]: Logger:
[18:10:55][C][logger:186]:   Level: DEBUG
[18:10:55][C][logger:187]:   Log Baud Rate: 115200
[18:10:55][C][logger:188]:   Hardware UART: UART0
[18:10:55][C][captive_portal:169]: Captive Portal:
[18:10:55][C][ota:029]: Over-The-Air Updates:
[18:10:55][C][ota:030]:   Address: kitchen_music.local:8266
[18:10:55][C][api:095]: API Server:
[18:10:55][C][api:096]:   Address: kitchen_music.local:6053
And there is nothing more when you put your tag near the reader?
I should have asked for your esphome yaml as well :slight_smile:
I just realized I may need the tagreader.yaml in my ESP8266, trying that now. I just had what ESPHOME put on it, which is basically just the WiFi info.
Yeah your log is pretty sparse. I assume you are using adonno’s firmware?
Yep. I loaded the tagreader.yaml and it works now, thanks
How to upload it to esp8266 ? in secrets ?
