Tailscale problem - running as exit node
I cannot connect from outside to home assistant
On my phone it says that my phone and home assistant are connected
When I try to connect to HA it says err connection time out or error loading HA
When I look on my pc it says :
“Running as exit node - Pending approval to run as exit node. This device won’t be usable as an exit node until then.”
I cannot find:
  • option to disable running as exit node
  • or give approval
Hope somebody can help me
It will not act as an exit node unless you specifically approve it, so if you are happy with the current config just leave it
In your browser go to Tailscale and log into the Tailscale admin console. Navigate to the HA machine listing, click on that and scroll down to routing settings to approve as an exit node.
Ok, thanks, this helps. I gave it approval for the time being. I do not use exit nodes, ik think, so i can disable exit nodes without problems?
Hello, I have not approved any of my 14 machines scattered across different geographical locations as exit nodes. Everything is working perfectly. I do not want any of these machines to route local traffic.
ok, thanks
