I’m using Tailscale to access HA when out of home and also access another HA in a second home. Up to version 0.28 I was connected 24/7 with TS up and running without issues. Via Tailscale I was able to browse my cameras using their respective IP’s without issues. Now after I upgraded to 0.29, Tailscale is connected but can only access HA via TS IP, which is OK, but I can’t see the cameras anymore.
Any idea? I restored version 0.28 and everything when back as it was before. All settings are the same as they were before…
Update:
By adding the subnet IP + CIDR in the “Advertise subnet routes” under the TS configuration, the problem is solved…
