Issue Summary:
I am encountering an issue when attempting to take control of the official Home Assistant Voice Assistant hardware (sold at the end of 2024) via ESPHome. The device is online, visible, and fully functional under Home Assistant integrations—I can interact with it and issue commands. However, when I try to “Take Control” of the device using ESPHome, I encounter the following error:
INFO ESPHome 2024.12.4
INFO Reading configuration /config/esphome/home-assistant-voice-09116b.yaml...
ERROR Unexpected exception while reading configuration:
File "/usr/local/bin/esphome", line 8, in <module>
sys.exit(main())
File "/esphome/esphome/__main__.py", line 1036, in main
return run_esphome(sys.argv)
FileNotFoundError: [Errno 2] No such file or directory: '/data/packages/dc43710d/.git/HEAD'
Environment Details:
• Device: Official Home Assistant Voice Assistant hardware (2024 release).
• Host Environment: Proxmox running HassOS.
• ESPHome Version: 2024.12.4.
• All software and firmware are up-to-date.
Steps Taken:
1. Verified the device is functional and visible in Home Assistant integrations.
2. Reproduced the issue with another device—same result.
3. Verified all components are running the latest versions.
Suspected Issue:
The error appears related to ESPHome’s package management or Git system (/data/packages/dc43710d/.git/HEAD is missing). It might indicate a corrupted package cache or incomplete configuration.
Request:
Please advise on potential fixes or steps to resolve this issue. Logs and additional details can be provided upon request.
Thank you for your support!
