Tap_Action / Script / Variable
I am trying to use a script to trigger a new snapshot of my Blink cameras when you tap on the picture showing the latest image in Blink. Here is my script in script.yaml created using the editor:
'1561792875210':
  alias: Blink Camera Snapshot
  sequence:
  - service: blink.trigger_camera
  - delay: 00:00:05
  - service: blink.blink_update
  - service: camera.snapshot
And here is my card:
type: vertical-stack
cards:
  - type: horizontal-stack
    cards:
      - type: picture-glance
        entities: []
        camera_image: camera.blink_front_door
        tap_action:
          action: call-service
          service: script.1561792875210
            camera_name: Front Door
        entities: []
        camera_image: camera.blink_garage_door
        tap_action:
            camera_name: Garage Door
    cards:
      - type: glance
        entities:
          - entity: sensor.blink_front_door_battery
          - entity: sensor.blink_front_door_temperature
          - entity: sensor.blink_front_door_wifi_signal
        show_name: false
      - type: glance
        entities:
          - entity: sensor.blink_garage_door_battery
          - entity: sensor.blink_garage_door_temperature
          - entity: sensor.blink_garage_door_wifi_signal
        show_name: false
    cards:
        entities: []
        camera_image: camera.blink_back_yard_right
        tap_action:
            camera_name: Back Yard - Right
        entities: []
        camera_image: camera.blink_side_door
        tap_action:
            camera_name: Side Door
    cards:
      - type: glance
        entities:
          - entity: sensor.blink_back_yard_right_battery
          - entity: sensor.blink_back_yard_right_temperature
          - entity: sensor.blink_back_yard_right_wifi_signal
        show_name: false
      - type: glance
        entities:
          - entity: sensor.blink_side_door_battery
          - entity: sensor.blink_side_door_temperature
          - entity: sensor.blink_side_door_wifi_signal
        show_name: false
But clicking on the picture from the Blink camera does nothing. If i hard code the variable name in the script and just trigger the script, the picture from the Blink camera does update. I’ve spent 2 hours looking at documentation but not solution yet! Can someone help please?
service_data, not data.
        tap_action:
          service_data: ##### <----
Thank you but I still cannot get this to work. Here is my script:
blink_snapshot:
  alias: Blink Snapshot
  sequence:
      name: '{{ camera_name }}'
  - delay: 00:00:05
  - delay: 00:00:05
      entity_id: '{{ camera_entity_id }}'
      filename: '/share/{{ camera_entity_id }}_{{ now().strftime("%Y%m%d-%H%M%S") }}.jpg'
And here is the card I am trying to use this in:
cards:
  - cards:
      - camera_image: camera.blink_front_door
        entities: []
        tap_action:
          service: script.blink_snapshot
          service_data:
            camera_entity_id: camera.blink_front_door
      - camera_image: camera.blink_garage_door
        entities: []
        tap_action:
          service_data:
            camera_entity_id: camera.blink_garage_door
  - cards:
      - entities:
        show_name: false
        type: glance
      - entities:
        show_name: false
        type: glance
  - cards:
      - camera_image: camera.blink_back_yard_right
        entities: []
        tap_action:
          service_data:
            camera_entity_id: camera.blink_back_yard_right
      - camera_image: camera.blink_side_door
        entities: []
        tap_action:
          service_data:
            camera_entity_id: camera.blink_side_door
  - cards:
      - entities:
        show_name: false
        type: glance
      - entities:
        show_name: false
        type: glance
If I hard code the two variables passed by the service call then the script works. But when I try to use variables, nothing happens.
Elvis
Try:
          service_data:
            camera_name: 'Front Door'
Unfortunately, it still does not work. Is there a way to “print out” what the variable in the script is getting passed to it? It seems that somehow the camera name isn’t passing correctly, which makes the script fail to do anything.
I suppose you could store it in an input.text.
EDIT: You need to adjust your script to use data_template:, not data:
blink_snapshot:
  sequence:
    data_template: ###### <--------- Here
  - delay: 00:00:05
  - delay: 00:00:05
    data_template: ###### <--------- And here
Thank you that fixed it!
No matter what I do this takes half pictures. It only processes the top half of the snapshot.
