I would need some help how to solve the user interaction with the wall switches (not existing at the moment, I’m in a planning phase).
I would like to identify tap, double (or multiple) tap and tap&hold. Single and multiple taps are not a real issues at all, but the tap&hold is still a big unknown to me.
The usage scenario for the tap&hold is something that is - for sure - already solved:
- light dimmer (dimming slowly while I hold the button)
- window blinds (rotating/sliding until while I hold the button)
- audio volume settings
Any idea? What are the propper events to generate via the switch?
- tap_hold start + tap_hold end
- repeating tap_hold_active for example every 0.2s
How to integrate that event to HA?
How tointegrate similar functionality to HA frontend?
I think I’m hardly the first one to solve something similar because same use cases would be at every second HA installation…
