I just realized there is a problem with integration which was working fine until recently. Im not sure whene this occured first time, so cannot realte it to certain update. I’m not much into the topic, I hope someone could help. Here is what I get as error in notification centre:
Logger: homeassistant.setup
Source: setup.py:334
First occurred: 9:28:26 AM (1 occurrences)
Last logged: 9:28:26 AM
Setup failed for custom integration ‘taphome’: Unable to import component: cannot import name ‘DEVICE_CLASS_CONNECTIVITY’ from ‘homeassistant.components.binary_sensor’ (/usr/src/homeassistant/homeassistant/components/binary_sensor/init.py)
File “/usr/src/homeassistant/homeassistant/loader.py”, line 1015, in async_get_component
comp = await self.hass.async_add_import_executor_job(
self._get_component, True
File “/usr/local/lib/python3.13/concurrent/futures/thread.py”, line 59, in run
File “/usr/src/homeassistant/homeassistant/loader.py”, line 1075, in _get_component
ComponentProtocol, importlib.import_module(self.pkg_path)
File “/usr/src/homeassistant/homeassistant/util/loop.py”, line 200, in protected_loop_func
return func(*args, **kwargs)
File “/usr/local/lib/python3.13/importlib/init.py”, line 88, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File “”, line 1387, in _gcd_import
File “”, line 1360, in _find_and_load
File “”, line 1331, in _find_and_load_unlocked
File “”, line 935, in _load_unlocked
File “”, line 1026, in exec_module
File “”, line 488, in _call_with_frames_removed
File “/config/custom_components/taphome/init.py”, line 35, in
from .binary_sensor import BinarySensorConfigEntry
File “/config/custom_components/taphome/binary_sensor.py”, line 4, in
from homeassistant.components.binary_sensor import (
…<4 lines>…
ImportError: cannot import name ‘DEVICE_CLASS_CONNECTIVITY’ from ‘homeassistant.components.binary_sensor’ (/usr/src/homeassistant/homeassistant/components/binary_sensor/init.py)
File “/usr/src/homeassistant/homeassistant/setup.py”, line 334, in _async_setup_component
component = await integration.async_get_component()
File “/usr/src/homeassistant/homeassistant/loader.py”, line 1035, in async_get_component
self._component_future.result()
File “/usr/src/homeassistant/homeassistant/loader.py”, line 1027, in async_get_component
comp = self._get_component()
…<4 lines>…
