Tapo 115 connection refused
i have read this code :slight_smile:
Registratore: homeassistant.config_entries
Fonte: config_entries.py:749
Prima occorrenza: 21:19:02 (2 occorrenze)
Ultimo accesso: 21:41:00
Error setting up entry P115 P115 for tplink
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 749, in __async_setup_with_context
    result = await component.async_setup_entry(hass, self)
  File "/usr/src/homeassistant/homeassistant/components/tplink/__init__.py", line 170, in async_setup_entry
    device: Device = await Device.connect(config=config)
  File "/usr/local/lib/python3.13/site-packages/kasa/device.py", line 247, in connect
    return await connect(host=host, config=config)  # type: ignore[arg-type]
  File "/usr/local/lib/python3.13/site-packages/kasa/device_factory.py", line 80, in connect
    return await _connect(config, protocol)
  File "/usr/local/lib/python3.13/site-packages/kasa/device_factory.py", line 122, in _connect
    await device.update()
  File "/usr/local/lib/python3.13/site-packages/kasa/smart/smartdevice.py", line 271, in update
    await self._negotiate()
  File "/usr/local/lib/python3.13/site-packages/kasa/smart/smartdevice.py", line 218, in _negotiate
    resp = await self.protocol.query(initial_query)
  File "/usr/local/lib/python3.13/site-packages/kasa/protocols/smartprotocol.py", line 135, in query
    return await self._query(request, retry_count)
  File "/usr/local/lib/python3.13/site-packages/kasa/protocols/smartprotocol.py", line 140, in _query
    return await self._execute_query(
        request, retry_count=retry, iterate_list_pages=True
  File "/usr/local/lib/python3.13/site-packages/kasa/protocols/smartprotocol.py", line 328, in _execute_query
    return await self._execute_multiple_query(
        request, retry_count, iterate_list_pages
  File "/usr/local/lib/python3.13/site-packages/kasa/protocols/smartprotocol.py", line 247, in _execute_multiple_query
    response_step = await self._transport.send(smart_request)
  File "/usr/local/lib/python3.13/site-packages/kasa/transports/klaptransport.py", line 354, in send
    await self.perform_handshake()
  File "/usr/local/lib/python3.13/site-packages/kasa/transports/klaptransport.py", line 322, in perform_handshake
    local_seed, remote_seed, auth_hash = await self.perform_handshake1()
  File "/usr/local/lib/python3.13/site-packages/kasa/transports/klaptransport.py", line 177, in perform_handshake1
    response_status, response_data = await self._http_client.post(
        url, data=payload, ssl=await self._get_ssl_context()
  File "/usr/local/lib/python3.13/site-packages/kasa/httpclient.py", line 105, in post
    resp = await self.client.post(
    ...<8 lines>...
  File "/usr/local/lib/python3.13/site-packages/aiohttp/client.py", line 703, in _request
    conn = await self._connector.connect(
        req, traces=traces, timeout=real_timeout
  File "/usr/local/lib/python3.13/site-packages/aiohttp/connector.py", line 548, in connect
    proto = await self._create_connection(req, traces, timeout)
  File "/usr/local/lib/python3.13/site-packages/aiohttp/connector.py", line 1056, in _create_connection
    _, proto = await self._create_direct_connection(req, traces, timeout)
  File "/usr/local/lib/python3.13/site-packages/aiohttp/connector.py", line 1375, in _create_direct_connection
    transp, proto = await self._wrap_create_connection(
    ...<7 lines>...
  File "/usr/local/lib/python3.13/site-packages/aiohttp/connector.py", line 1115, in _wrap_create_connection
    sock = await aiohappyeyeballs.start_connection(
    ...<5 lines>...
  File "/usr/local/lib/python3.13/site-packages/aiohappyeyeballs/impl.py", line 73, in start_connection
    sock = await _connect_sock(
    ...<6 lines>...
  File "/usr/local/lib/python3.13/site-packages/aiohappyeyeballs/impl.py", line 208, in _connect_sock
    await loop.sock_connect(sock, address)
  File "/usr/local/lib/python3.13/asyncio/selector_events.py", line 641, in sock_connect
    return await fut
asyncio.exceptions.CancelledError
