Tapo C310 Stream + recordings lagging
Recently, my Tapo C310 Camera is lagging really badly. At first I only noticed the problem when recording a video via the record video HA service but since yesterday, the stream itself laggs. It can be seen on the timestamp of the video HERE.
I have two cameras in my system, integrated via the Tapo Camera Control Integration, a C212 and a C310. The Stream of the C212 works just fine and also the record video service is working fine, the problem is only with the C310. Both are connected via LAN and have a static IP Adress.
When i watch the stream in the Tapo App AND with an RTSP Link via go2rtc and webRTC, its fine, no lags BUT the recorded videos still lag
Thing i tried:
  • delete the Camera from Integration and reconfigured it with several different settings such as use HA Stream component on/off (disabling this also disables the “motion sensor” checkbox that i cant activate any more afterwards), sync time automaticly,…
  • delete the Camera from Tapo App itself and reconfigured it
  • restarted HA Host
nothing seems to work unfortunately. I already tried getting similar information about this problem but could not find anything related.
System is baremetal HA on HP Prodesk i5 9500t, 8GB Ram; latest HA Version, Integration also up to date.
I am having the same issue with a Tapo TC65
sadly i could not fix the problem so I installed an SD Card in the camera and sync the recorded footage to my media Folder in HA. It works well but takes up to 5 minutes until the video is available in my media folder.
Same issue here only when recording.
Frontend and live stream work flawlessly.
The action camera.record does not use webrtc stream. When recording, no stream appears on the net tab of the go2rtc debug_ui.
Any help to force it ?
Would you mind sharing the automation you use for syncing from SD card to HA?
