Tapo light presets with effects don’t work in Home Assistant automations / scenes
Hi everyone,
I’m running into a limitation (or bug?) with Tapo lights + Home Assistant, and I’m trying to confirm whether this is expected behavior or if there’s a workaround.
So I have a tapo integration also tp-link smart home (HACS) but the problem is that I want to make an automation where it changes the color to an effect. Since there is no change effect option I use change light preset and I customize the presets in the Tapo App. But it only works if the preset is a static color. If it has any effects than the HA cannot do anything with it. Like its not even there.
Someone suggested to use TP-Link Smart Home but I only found Random effect and Sequence effect options as an action which didn’t really help me.
I just want to use the effects that I made in the Tapo app.
Do you guys have any idea how to solve this?
