I installed my first Matter device a couple weeks ago, a Tapo P125M smart plug. I had no issues, it worked perfectly. After the last Matter update, and a HA core update it got unstable. When I toggle the switch on the dashboard, either web or companion app it immediately starts cycling back and forth until I press the button on the plug to stop it.
The switch wwas set up with the HA visual editor. Here is the yaml:
type: entities
entities:
- entity: switch.scott_bedroom_laptop_charger_2
title: Plugs
Now the strange part is I also set up the switch on an Elecro 7" touch panel. Here is the yaml:
switch:
- platform: homeassistant
entity_id: switch.scott_bedroom_laptop_charger_2
on_state:
then:
- lvgl.widget.update:
state:
checked: !lambda return x;
internal: true
This works without a problem. What am I missing?
