Tapo not run after latest update
Hi. After latest update I can’t install the TAPO integration. I get this error:
`Failed to load configuration stream: {"message":"Invalid handler specified"}
and I found ths error in my log:
2023-05-11 14:25:37.434 ERROR (MainThread) [homeassistant.config_entries] Error occurred loading flow for integration tapo_control: cannot import name 'NotificationManager' from 'onvif.client' (/usr/local/lib/python3.10/site-packages/onvif/client.py)
2023-05-11 14:30:34.421 WARNING (Thread-12) [pychromecast.socket_client] [CC Soggiorno(192.168.1.104):8009] Heartbeat timeout, resetting connection
2023-05-11 14:31:04.469 ERROR (Thread-12) [pychromecast.socket_client] [CC Soggiorno(192.168.1.104):8009] Failed to connect to service ServiceInfo(type='host', data=('192.168.1.104', 8009)), retrying in 5.0s
2023-05-11 14:33:44.881 ERROR (MainThread) [frontend.js.latest.202305033] :0:0 ResizeObserver loop completed with undelivered notifications.
How can I fix? Thanks
My version is;
Home Assistant 2023.5.2 Supervisor 2023.04.1 Operating System 10.1 Frontend 20230503.3 - latest
You have a custom component installed that is pinning the onvif library to the wrong version
Thank you for your suggestion.
Is there a way, by inspecting the logs to figure out which component causes the error?
